Disconnects and ongoing poor quality
I am experiencing multiple dropouts on a daily basis and very poor quality in both voice and with failed transfers. The Router has experienced some major resets with a loss of Internet and Wifi. Also reporting loss of sync on Cable on multiple occasions, I have attached Logs and DPM
Re: Disconnects and ongoing poor quality
1299000000-3.931256 qam21
2139000000-3.233256 qam1
3147000000-3.232256 qam2
4155000000-3.732256 qam3
5163000000-431256 qam4
6171000000-3.731256 qam5
7179000000-3.532256 qam6
8187000000-3.531256 qam7
9195000000-3.731256 qam8
10203000000-3.731256 qam9
11211000000-3.731256 qam10
12219000000-3.731256 qam11
13227000000-4.231256 qam12
14235000000-4.530256 qam13
15243000000-4.731256 qam14
16251000000-4.531256 qam15
17259000000-4.731256 qam16
18267000000-4.731256 qam17
19275000000-4.531256 qam18
20283000000-431256 qam19
21291000000-3.931256 qam20
22307000000-431256 qam22
23315000000-431256 qam23
24323000000-3.732256 qam24
1Locked31.68691925159482
2Locked33501150150173
3Locked32.9457157150952
4Locked32.22350162156909
5Locked31.67549593161223
6Locked31.66797971159701
7Locked32.23018163153560
8Locked31.94653610158827
9Locked31.610005599162502
10Locked31.69567400162135
11Locked31.94717547152385
12Locked31.94254532154109
13Locked3118809504164349
14Locked30.834465840166464
15Locked31.315975867161668
16Locked31.93778031145830
17Locked31.95395540155914
18Locked31.121561122166297
19Locked31.124361996167270
20Locked31.67965822159118
21Locked31.93596203154191
22Locked31.313014564168984
23Locked31.65866544157404
24Locked32.51247839150949
1537000004.35512064 qam2
2394000004.15512064 qam4
3462000004.225512064 qam3
4603000004.35512064 qam1
3ATDMA0000
4ATDMA0000
29/10/2020 12:26:5Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/10/2020 12:26:5criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/10/2020 12:25:48Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/10/2020 12:25:48criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/10/2020 12:25:39Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/10/2020 12:25:39criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/10/2020 09:58:29Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/10/2020 09:58:29criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/10/2020 09:25:52Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/10/2020 09:25:47criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/10/2020 09:25:33Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/10/2020 09:25:33criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/10/2020 09:13:15Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/10/2020 09:13:15criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/10/2020 07:54:53Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/10/2020 07:54:53criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/10/2020 07:54:47Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/10/2020 07:54:47criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/10/2020 07:08:38Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/10/2020 07:08:38
https://www.thinkbroadband.com/broadband/monitoring/quality/share/bd05aae4bab050a3fcfd0fe831656a40dd...
28/10
https://www.thinkbroadband.com/broadband/monitoring/quality/share/647e90f793ac89dd749a2b3c1030bc66e061be2a-28-10-2020
  • 25.12K
  • 1.44K
  • 3.2K
Your downstream levels are too low.
When was the hub last rebooted and is there an attenuator fitted to the hub?
