Disappointed in Virgin Media Hub 3
AlphaOne
I had a Hub 3 installed yesterday. The technician didn't have time to stay and check everything was working. It took me quite a while to get everything working but it seemed to be okay last night. This morning it is not recognising any ethernet connections. There is a green light on the router ethernet port, I have checked all the cables and reset everything.
Very disappointing start, glad I have kept my BT account open.
7 REPLIES 7
Legend
Login to the Hub3 at http://192.168.0.1/ use the 8 DIGIT password from the bottom of the Hub 3.
When logged in, the first page of the menu has status info, what does it report the internet ?
Hi, thanks for the interest. Internet and Wi-Fi are working okay and the status is good. The problem is the router doesn't recognize anything plugged into the Ethernet ports, even though it did yesterday.
Legend
Try a factory RESET of the Hub 3.
Press and hold the rear RESET button for 60 seconds and then leave the Hub 3 turned on to revert to the shipping state. This can take some time to complete.
Failing this we are looking at a fault that will need to be reported to Customer Services via 150 or 0345 454 1111 from a non-VM phone.
Is the 0345 number free from a non-VM phone?
Thanks. I tried the factory reset but that didn't help. I tried the customer support number you gave me but that was no help. Sadly I will have to cancel my contract.
Legend
