  • 19
Message 1 of 24
Disabling WIFI
i’ve disabled the 2.4 and 5ghz WIFI signals on my hub3 router but I’m still getting the same RF levels even when they are both enabled.
when I switch to modem mode RF readings are zero.
is my hub3 faulty or maybe a firmware update might fix it?
i only want to have a wired network.
Appreciate any help, thank you
  • 14.3K
  • 592
  • 1.37K
Message 2 of 24
Re: Disabling WIFI
Likely VM public wifi.
disable it in your account
  • 19
Message 3 of 24
Re: Disabling WIFI
Thank you, I opted out Tuesday, tested yesterday but still getting the same RF levels.
Could it be a faulty Hub3?
  • 4.45K
  • 261
  • 521
Message 4 of 24
Re: Disabling WIFI
Hello Fez81
Sorry you are still having issues
I have had a look and we have an SNR Issue in the area
This is due to be fixed on the 18/05/2020
The reference number we have is F008024658
Just pop back on here and we cab chase this up for you
Gareth_L
  • 19
Message 5 of 24
Re: Disabling WIFI
Hi Gareth,
I have just checked my hub3 again in router mode with WIFI disabled, there is still high levels of RF, the same levels as when WIFI is enabled.
Disabling WIFI only means I can’t use it but the signal is still present.
Hardware version 10
software version 9.1.1811.401
  • 20.96K
  • 1.14K
  • 2.7K
Message 6 of 24
Re: Disabling WIFI
What’s your point/problem/issue?
  • 6.08K
  • 310
  • 539
Message 7 of 24
Re: Disabling WIFI
Hi fez81,
I am sorry it's still ongoing. I have checked today and there is still an ongoing SNR issue. Fault reference is F008039497. Estimated fix date is the 27th May.
Kind regards,
John_GS
  • 19
Message 8 of 24
Re: Disabling WIFI
Hi John,
Has this been fixed?
I’m still having the same issue.
kind regards
  • 14.3K
  • 592
  • 1.37K
Message 9 of 24
Re: Disabling WIFI
Just use modem mode likely a bug with the firmware for not turning off the wireless correctly and may never get fixed.
  • 19
Message 10 of 24
Re: Disabling WIFI
Can I be sent a cable router with no WIFI capabilities?
or are there any buying options?
when I use the hub3 as a cable modem with a wired router connected I get 20-30mbps
