AB1918
  • 12
Message 1 of 20
Disable LED on Hub 4
Is there any way of disabling the unnecessarily large LED on the Hub 4?
It is just pointless the strip of bright white light being constantly on. All other devices  I own have this facility it does not of course disable warning lights.
BenMcr
  • 22.72K
  • 2.5K
  • 4.79K
Message 2 of 20
Re: Disable LED on Hub 4
Yes, in the admin pages. It's possible to turn the light ring off or down.
gary_dexter
  • 32.63K
  • 2.02K
  • 4.46K
Message 3 of 20
The light ring is also the notification ring. So if you turn it off you won’t see any notifications as there’s no LED icons.
AB1918
  • 12
Message 4 of 20
Thanks. Where do I find the admin pages?
DJ_Shadow1966
  • 7.24K
  • 1.38K
  • 2.1K
Message 5 of 20
Hello
If you click on http://192.168.0.1 the login details are on the base of the hub.
Regards Mike
AB1918
  • 12
Message 6 of 20
Brilliant, thank you so much. I have left the light band on 1%.
AB1918
  • 12
Message 7 of 20
Have a look at the other reply I received on this topic.
There's some excellent and helpful information you may find useful.
Gmann9116
  • 27
Message 8 of 20
Hi 🤜
Great Post & link 👍 but not sounding too Fick 😉!
What's the procedure when in the linked Admin Page" to Turn Off/Down the white light......🤔!!!!!
Cheers 🍻
Zak_M
  • 6.12K
  • 315
  • 545
Message 9 of 20
Good afternoon @Gmann9116
Welcome back to the forums, and thank you once again for your post.
Please can you let me know the model of hub you have?
Kind regards,
Zak_M
Gmann9116
  • 27
Message 10 of 20
Hi 🤜
The same VBox
