Mario64
  • 8
Devices lose connection regularly
I'd really appreciate a hand with debugging this.
I've found that some devices work consistently, no problem, others constantly need reconnected and get can get stuck at the "obtaining IP address" stage. Restarting the hub can help, but within a couple of days, the same device will have connection issues again.
The router is in an adjacent room, the 5Ghz and 2Ghz networks have different names, the signal strength appears good on the affected devices and the same devices did not have issues on previous networks.
Is there a way to tell why these devices can't properly connect on the router itself?
Network Log:
14/04/2021 04:25:5Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/04/2021 04:25:4Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/04/2021 04:22:33Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/04/2021 04:22:32Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/04/2021 04:18:43Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/04/2021 04:18:41Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/04/2021 04:16:47Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/04/2021 04:16:46Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/04/2021 04:15:40Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/04/2021 04:15:40Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/04/2021 04:12:8Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/04/2021 04:12:8Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/04/2021 04:11:54Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/04/2021 04:11:53Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/04/2021 04:11:32Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/04/2021 04:11:32Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/04/2021 04:11:0Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/04/2021 04:11:0Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/04/2021 04:10:13Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/04/2021 04:10:12Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Mario64
  • 8
Re: Devices lose connection regularly
Hit the character limit.
Downstream:
1331000000-240256 qam25
2203000000-0.240256 qam9
3211000000-0.740256 qam10
4219000000-0.737256 qam11
5227000000-0.934256 qam12
6235000000-1.240256 qam13
7243000000-1.440256 qam14
8251000000-1.740256 qam15
9259000000-1.740256 qam16
10267000000-1.540256 qam17
11275000000-1.740256 qam18
12283000000-1.540256 qam19
13291000000-1.540256 qam20
14299000000-1.240256 qam21
15307000000-1.540256 qam22
16315000000-240256 qam23
17323000000-2.240256 qam24
18371000000-2.940256 qam26
19379000000-2.740256 qam27
20387000000-3.240256 qam28
21395000000-2.940256 qam29
22403000000-340256 qam30
23411000000-3.438256 qam31
24419000000-3.540256 qam32
1Locked40.3770
2Locked40.917340
3Locked40.3100710
4Locked37.64022385
5Locked34.4151677705200625037
6Locked40.38211
7Locked40.382111
8Locked40.310304
9Locked40.35550
10Locked40.916577
11Locked40.34565
12Locked40.3254
13Locked40.91290
14Locked40.32680
15Locked40.9931
16Locked40.31703
17Locked40.3990
18Locked40.92710
19Locked40.32520
20Locked40.3160
21Locked40.9150
22Locked40.380
23Locked38.960
24Locked40.390
13940000049.5512016 qam12
24620000051512016 qam11
35370000051512016 qam10
46030000051512016 qam9
3ATDMA0000
4ATDMA0000
lotharmat
  • 876
  • 61
  • 125
Well-informed
Upstream looks borked (too high power and 16 QAM - should be 64
Downstream some channel SNR looks too low and loads of PostRS errors!
I'd say an engineer is needed!
Gareth_L
  • 6.13K
  • 376
  • 663
Hello Mario64
Sorry to hear this is happening
The down stream levels are just a bit out of the range we need
I have booked the first engineer appointment we have available
You can check and reschedule this appointment through your online account if you need to
You can also cancel it if the fault has gone
Can you please let me know how the visit goes
Gareth_L
Mario64
  • 8
Hi, thank you very much for arranging the enginner.
The engineer addressed a few problems on the 19th that apparently could have been causing interference. The error section of the router page has only seen two "No Ranging Response received" errors since which suggests it's improved.
Hopefully that's it sorted. Thanks for all the help.
Robert_P
  • 2.51K
  • 124
  • 206
Thanks for the update Mario64 and glad to hear the engineer was able to help resolve the issue.
Monitor it going forward and if you need us again please don't hesitate to get in touch.
Rob
