Maddy8125
  • 15
Message 1 of 27
Devices keep
I’m totally sick of virgin. Since we signed up devices randomly drop out. We were promised signal boosters as the signal doesn’t even reach upstairs. This is not the service I am paying for.
TimePriorityDescription22/04/2021 22:22:7criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;22/04/2021 01:51:35ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;21/04/2021 18:47:13criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;21/04/2021 17:29:46Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;18/04/2021 13:51:34ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;15/04/2021 00:54:2criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;15/04/2021 00:53:36criticalStarted Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;15/04/2021 00:53:7criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;15/04/2021 00:43:57criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;15/04/2021 00:41:16Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;15/04/2021 00:41:12criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;15/04/2021 00:41:11Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;08/04/2021 19:05:44criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;07/04/2021 04:48:43ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;05/04/2021 17:51:19criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;03/04/2021 16:48:43ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;02/04/2021 18:08:48criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;31/03/2021 04:48:43ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;28/03/2021 00:35:26criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;27/03/2021 15:48:43ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
lotharmat
  • 838
  • 56
  • 118
Well-informed
Message 2 of 27
Re: Devices keep
Can you post the rest of your Hub status and logs?
Someone should be spot if there is a problem
Maddy8125
  • 15
Message 3 of 27
Re: Devices keep
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
cmreg-vmdg505-bbt060+voc-b.cm
SFID6972
Max Traffic Rate230000061
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID6971
Max Traffic Rate22000061
Min Traffic Rate0
Max Concatenated Burst42600
Scheduling TypeBestEffort
13940000037.5512064 qam8
26030000038.3512064 qam5
35370000038512064 qam6
44620000037.8512064 qam7
3ATDMA0020
4ATDMA0010
11390000009.540256 qam1
21470000009.840256 qam2
31550000009.640256 qam3
41630000009.540256 qam4
51710000009.540256 qam5
61790000009.440256 qam6
71870000009.440256 qam7
81950000009.340256 qam8
9203000000940256 qam9
102110000008.840256 qam10
112190000008.640256 qam11
122270000008.540256 qam12
132350000008.540256 qam13
142430000008.440256 qam14
152510000008.440256 qam15
162590000008.440256 qam16
172670000008.540256 qam17
182750000008.540256 qam18
192830000008.540256 qam19
202910000008.440256 qam20
212990000008.540256 qam21
223070000008.140256 qam22
233150000008.140256 qam23
243230000008.340256 qam24
Maddy8125
  • 15
Message 4 of 27
Re: Devices keep
1Locked40.3130
2Locked40.9100
3Locked40.9180
4Locked40.9170
5Locked40.9190
6Locked40.9170
7Locked40.9190
8Locked40.9160
9Locked40.960
10Locked40.950
11Locked40.980
12Locked40.360
13Locked40.960
14Locked40.9130
15Locked40.3100
16Locked40.360
17Locked40.3200
18Locked40.9100
19Locked40.990
20Locked40.9110
21Locked40.3110
22Locked40.9130
23Locked40.9120
24Locked40.9120
139000000
Locked
Ranged Upstream Channel (Hz)
39400000
Locked
Provisioning State
Online
Akua_A
  • 575
  • 12
  • 35
Message 5 of 27
Re: Devices keep
Hi @Maddy8125,
Welcome to our community forums and thank you for your first posts.
Sorry to hear you are experiencing drop outs with your devices. I have been able to access your account using forum details. I can see your hub is currently offline. Are you able to reboot the device so I can best determine what the problem may be?
Akua_A
Maddy8125
  • 15
Message 6 of 27
Re: Devices keep
I’m not sure why it’s showing as offline when I’m currently using the internet?
  • 2.87K
  • 214
  • 610
Trouble shooter
Message 7 of 27
Re: Devices keep
Your Downstream power is nearly at the top of the range, it needs an engineer to bring that down a bit.  Also you should not be getting those SYNC errors.
Setup a BQM here www.thinkbroadband.com/ping  for comment.  This will monitor your connection 24x7 and show the state of the incoming circuit.
Maddy8125
  • 15
Message 8 of 27
Re: Devices keep
[url=https://www.thinkbroadband.com/broadband/monitoring/quality/share/6308256c90e1dca11eaddd6dd1f4bf9cfa578e20-25-04-2021]My Broadband Ping[/url]
that was yesterday
Akua_A
  • 575
  • 12
  • 35
Message 9 of 27
Re: Devices keep
Thanks for letting us know @Maddy8125
Just to confirm, have you rebooted the device as it is still reading offline?
Akua_A
Maddy8125
  • 15
Message 10 of 27
Re: Devices keep
It’s is currently rebooting.
