Delete Home Wifi Network
Osattar
Hello, I added a new Home Network to create a seperate 2Ghz Network for my light bulb. Now I want to delete this Network but there is no option to delete. How do I delete it and undo the network I added?
5 REPLIES 5
ttt3
No idea. Is the light bulb still working though 💡
Just do a 60 second pinhole reset on the Hub.  This will reset it back to factory settings.
Robert_P
Hi Osattar,
Thanks for posting in regards to removing the additional 2.4ghz network you set up, we appreciate you taking the time to raise this via the forums.
As Adduxi has stated, the quickest way to do this would be to reset the hub, please be aware that this will revert it back to factory settings removing any connected devices and resetting any changes you may have made to the network.
If you need us further, don't hesitate to get in touch and we'll be happy to help.
Rob
Yep still work
Legend
Having previously used the Hub's menu to change the Hub's SSID for the 2.4Ghz band to a new value, now use the Hub's menu once again and revert to the 2.4 band to the original SSID.
