jwilk
Deco/Hub 3/Switch
So, I have a Hub 3 in modem mode, connected to a Deco via cable into a TP link 8 port switch worked fine, strong 200mb +wifi
Recently had a power cut, powered it all back up, no internet
Restarted modem mode, connected Deco and re set, that's fine
Connected switch, deco goes to red light no internet
Before I buy a new one, firstly probably the switch has a fault after power outage ? then, is there a particular switch that is more compatible (Netgear GS 108)
jwilk
Re: Deco/Hub 3/Switch
Currently have a TP link
TL-SG1008D Network Switch - 8-port
  • 3.19K
  • 249
  • 694
Can you just confirm your connection is as below?
Hub ---> Deco ---> Switch
Can't see any reason why connecting a switch would cause the Deco to fail unless the switch is borked?  My own switches at home are unmanaged TP-Link ones and don't give any bother.
jwilk
Yep that's the one
Now got a PC ethernet into the Deco direct and it's fine
Must be the switch was cooked - odd, as it's blinking away with connections, just throws the Deco into red
