cameronA92
Message 1 of 5
Damaged hub 3 need a replacement - how do I get a new one!!
so i need some help please for the last few weeks the wifi part of my hub keeps failing i will reboot it sometimes it works then others it wont and when it does work it only works for a few hours then wont allow anything to connect to it again and with 4 kids in the house its maddness with no wifi.
 ive contact virgin more then enough now over this and keep getting fobbed off and they are refusing to replace my hub how do i get a new one please before i LEAVE
  • 35.06K
  • 3.41K
  • 6.67K
Message 2 of 5
Re: Damaged hub 3 need a replacement - how do I get a new one!!
Your title says "Damaged Hub3" .... what damage has it sustained?
What are they saying when you call in to report it as a fault ?
Lee_R
  • 6.84K
  • 320
  • 732
Message 3 of 5
Hi @cameronA92, thanks for posting and welcome to our community.
Sorry to hear you're having a poor WiFi experience and for any inconvenience this may be causing your household.  As it sounds like a pinhole reset is not fully fixing your issue, I would like to take a closer look on your behalf. I am going to send you a private message. Please look out for the purple envelope in the top right of your screen.
Lee
cameronA92
Message 4 of 5
This WiFi part keeps failing and won't allow anything to connect part the wired devices work fine
Lee_R
  • 6.84K
  • 320
  • 732
Message 5 of 5
Hi @cameronA92, thanks for getting back to me privately.
This is just a quick note to confirm you're satisfied with the response and efforts of the forum team?  Remember, if you ever need assistance in the future, our fantastic community and forum team are always willing to lend a hand. Please bear in mind, you can manage your account from here. Your online account, will give you access to your bills, show your package details, diagnose any possible faults and monitor any orders and appointments you may have.
Lee_R
