Damaged Hub 3 - I need help with replacement please
itsallshots
Dear All,
I really need some help, I've got a failing Hub 3, WifFi strength pretty much drops off to 1-2 meg when outside the room and constant drop out connections over the past 3 months, which before was ideal.  I have been speaking to various customer service/technical support staff and keep getting bounced back and forth with simple "have you restarted your router".
Really appreciate any help someone can give me!
Many thanks,
1 REPLY 1
Nathan_B
Hi there @itsallshots 👋 Welcome to our forum and thanks for your post 😊
Sorry to see you've been having some issues with the WIFI on your Hub 3, we'd certainly be happy to help with this further so this can be resolved.
So this can be done, I'll send you a PM to confirm your details.
Nathan
