JackHendon
  • 7
Message 1 of 7
Daily outages - significant packet loss - hub 3.0
Hello,
For the past couple of weeks I've been experiencing significant downtime and cut outs. There doesn't appear to be any consistent pattern to the timings, some days it will be constant throughout the day, some days will be fine, and others will be an hour or two of issues and then it resolves itself.
The light on the Hub 3.0 will either stay solid orange as usual or start flashing green, this is also not consistent with the drop outs. Below is a snapshot of a BQM for the last 24 hours - link here for the full view.
Really hoping someone can help me as working from home is becoming unsustainable with how frequent the issues have become. Have pasted full network info below but let me know if you need anything else. Thanks.
Cable Modem StatusItem Status Comment
331000000
Locked
Ranged Upstream Channel (Hz)
23600000
Locked
Provisioning State
Online
13310000003.740256 qam25
2203000000440256 qam9
32110000004.440256 qam10
42190000004.540256 qam11
52270000004.540256 qam12
62350000004.640256 qam13
72430000004.340256 qam14
8251000000440256 qam15
92590000003.740256 qam16
102670000003.740256 qam17
112750000003.740256 qam18
122830000003.940256 qam19
132910000004.140256 qam20
14299000000440256 qam21
153070000004.340256 qam22
16315000000440256 qam23
173230000003.940256 qam24
183390000003.740256 qam26
19347000000440256 qam27
203550000004.340256 qam28
213630000004.640256 qam29
223710000004.840256 qam30
233790000005.340256 qam31
24387000000538256 qam32
1Locked40.300
2Locked40.350
3Locked40.350
4Locked40.340
5Locked40.350
6Locked40.340
7Locked40.300
8Locked40.960
9Locked40.350
10Locked40.350
11Locked40.360
12Locked40.900
13Locked40.360
14Locked40.350
15Locked40.350
16Locked40.300
17Locked40.350
18Locked40.300
19Locked40.300
20Locked40.900
21Locked40.350
22Locked40.350
23Locked40.350
24Locked38.900
12360000049512064 qam5
23010000049512064 qam4
34960000047.8512064 qam1
2ATDMA0010
3ATDMA0024
SFID15966
Max Traffic Rate287500061
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID15965
Max Traffic Rate27500061
Min Traffic Rate0
Max Concatenated Burst42600
Scheduling TypeBestEffort
JackHendon
  • 7
Message 2 of 7
Re: Daily outages - significant packet loss - hub 3.0
10/03/2023 22:11:10Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/03/2023 22:11:9criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/03/2023 22:11:8criticalUnicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/03/2023 22:11:8Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/03/2023 22:10:49criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/03/2023 22:10:48criticalUnicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/03/2023 22:09:29criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/03/2023 22:09:29criticalUnicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/03/2023 22:09:9criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/03/2023 22:09:9criticalUnicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/03/2023 22:08:49criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/03/2023 22:08:49criticalUnicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/03/2023 22:08:44criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/03/2023 22:08:30criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/03/2023 22:08:30criticalUnicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/03/2023 22:07:24criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/03/2023 22:07:14criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/03/2023 22:07:13criticalUnicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/03/2023 22:06:56criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/03/2023 22:06:54criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Adri_G
  • 1.9K
  • 63
  • 119
Message 3 of 7
Hey JackHendon, thanks for reaching out on the help forum and sorry to see you've been experiencing issues with your services.
We'd love to best help with these, from our latest checks we haven't found an area fault or outage that is affecting you.
Could you please tell us if the problem is present on one device or more?
Also, how do these devices connect? Is it wirelessly or over ethernet?
How do things look since you last posted on Friday and have you noticed any improvements?
Let us know and we're eager to help.
Adri - Forum Team
New around here?
  • 1.74K
  • 109
  • 399
Super solver
Message 4 of 7
Both sets of Upstream stats show 3 upstream channels.  Most Hubs have 4 or more.
You refer to significant packet loss, in what application is the packet loss being measured ?
JackHendon
  • 7
Message 5 of 7
Hello, the problem went quiet for a few days and seems to have returned this morning.
The issue is present across multiple devices including a Macbook, an Iphone, and a PS4. The Macbook and Iphone are wireless and the PS4 is connected via ethernet.
JackHendon
  • 7
Message 6 of 7
I've setup a BQM (linked below) which shows a large amount of dropped packets whenever the issues are occurring. The issue ceases for sometimes days at a time and then comes back for random intervals as short as a few minutes or as long as multiple hours.
https://www.thinkbroadband.com/broadband/monitoring/quality/share/f370a447d95f661dfb4bd59251c1917e87...
jpeg1
  • 7.5K
  • 389
  • 1.46K
Legend
Message 7 of 7
The packet loss shows clearly in the BQM in the original post, and in the link just posted.
That, together with the missing upstream channel, shows that there is a serious connection problem that needs to be fixed.
