k9sar
  • 6
Message 1 of 5
DOCSIS 3.1 downstream power levels & QAM 4096
Hi all,
New to the Gig1 service which is working fine in terms of throughput etc.
Purely out of interest I notice that my 3.1 downstream does not stay on QAM 4096, seems to end up 2048 but have also seen it drop to 1024.
Wondered if there are any hints below that might suggest why this should be?
3.1 Downstream channels
159964K1880QAM2048728
159Locked425.2387401580
Mon 28/06/2021 00:02:076CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2.;;CM-QOS=1.1;CM-VER=3.1;
Mon 28/06/2021 07:07:225MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-;CM-QOS=1.1;CM-VER=3.1;
Mon 28/06/2021 07:19:385DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-;CM-QOS=1.1;CM-VER=3.1;
lotharmat
  • 2.54K
  • 188
  • 462
Trouble shooter
Message 2 of 5
Re: DOCSIS 3.1 downstream power levels & QAM 4096
I think it *could* negatively impact your d/l speeds as it should be 4096 - alas I do not know enough about what could cause it to drop
Andrew-G
  • 7.06K
  • 1.22K
  • 3.08K
Message 3 of 5
Modulation drops in response to unfavourable line conditions, usually a degree of noise.  As there's plenty of headroom on the D3.1 channel, dropping modulation may not make any difference to the speed or performance of the connection, and VM won't assign a technician unless there's a demonstrable performance fault.
k9sar
  • 6
Message 4 of 5
Might it be better if the downstream power level were 3dB lower?
jem101
  • 1.72K
  • 238
  • 803
Message 5 of 5
Not really, no.
