Hi ZHackH,
Thanks for using the forums to get this issue with your connection looked into, I am sorry if this has been causing some frustration. I would be more than happy to look into this for you.
I think Goslow is right in saying lets just focus on the connection side of things, see whether it can be explained by the usual suspected faults and then I can resolve them for you.
However, if I cannot find any reasonable fault, or I do and get it resolved on my side but you still experience the issue, then I would need to leave you in the capable hands of the community as we can't offer support with DDOS attacks 😞
The first thing I want you to do is follow some simple advice -
- Can you log into your Online Account and perform a diagnostic test to see if it detects any issues?
- How is your Console connected to the Hub? WIFI or wired? (Sorry if this is already mentioned, there was a lot of info to read through on this thread!)
- Are the symptoms you're experiencing slow speeds or full drops in connection, where the Hub shows failure lights too?
That should be enough for me to go off for now, we'll continue after you've done those steps.
Megan_L
