@ZHackH wrote:
Hey goslow
The cables have been changed 3 times. Twice by myself and once by VM. Also a change in router which bought me a few days before the disconnect started again relentlessly. My Console, never moved. neither did either router and the cables being brand new...
<snip>
If that is so, I'd suggest that your VM connection needs further investigation based on the upstream stat's and the entries in the network log. Read the info here
https://community.virginmedia.com/t5/Speed/Hub-status-data-understanding-network-log-messages/td-p/4...
on 'RCS Partial Service' and T3 timeouts which appear in your network logs. You also have the 1970 date stamp in your network log which is also mentioned in the help topic in regard to noise issues. Is that all of your network log or have you edited the contents? There is not much in it if that's everything in it from end of November.
I don't think you are being attacked by your neighbour (or have been). I think you have a connection issue.
If VM has swapped your hub, I would expect your new hub would get a different IP address so any previous attack (if there ever was one) would be on the old IP address and your neighbour would not know the new one for a new hub.
In addition, just before Xmas, I had to look at the connection of a friend who was experiencing numerous disconnections and requiring a regular reboot of the hub. His upstream stat's were the same as yours (one channel on 16 QAM). VM swapped the hub, various cables and splitters and the problem went away but the upstream error still showed in his hub stat's. My friend is certainly not a gamer (web browsing only) and I guess VM's changes made sufficient improvement for him but without actually curing the problem. Gaming requires a good upstream and downstream connection so I am guessing that this is why you are experiencing the problem on your console.
If you have got the BQM running, just let it do its thing and let it run through a period when you experience the issue and the BQM should capture the disconnection (if it is your VM connection which is being affected).
You'll need some of the regular tech experts on here to advise further once you have a BQM to look at as well, alongside the hub stat's. They'll be able to add to (or correct!) what I have already suggested about your issue. Once you have got some BQM data crossing a time period in which you are disconnected, post that BQM graph for further comment and suggestions.
