Message 1 of 8
Crap wifi
My 100Mbs only gives 22Mbs 5mtrs away from the hub3. When I signed up I asked if I would get a good signal with Virgin as I am in a 2 bedroom bungalow and was told yes all through the bungalow. This I find is wrong and I am struggling to get a signal at my printer. My wifi was much better with Talktalk on a 36mbs contract. I cannot believe I lose 78mbs at 5 Mtrs in a bungalow. If I sit on the router I do get 100Mbs, What a let down Virgin is.
  • 14.77K
  • 622
  • 1.42K
Message 2 of 8
Re: Crap wifi
VM wifi is letting them down when it be better if they didn't do wifi so look at it like that and get your own wireless router with 1Gb ports and use the hub in modem mode.
  • 24.87K
  • 1.43K
  • 3.16K
Message 3 of 8
Re: Crap wifi
No one can promise WiFi speeds
Message 4 of 8
Re: Crap wifi
15Mbs loss per metre is having a laugh
Message 5 of 8
Re: Crap wifi
This is not an unsolvable problem. You can strengthen your Wi-Fi signal by getting a quality access point. If you still run into problems, write here and I'll try to help.
Best regards.
  • 24.87K
  • 1.43K
  • 3.16K
Message 6 of 8
Re: Crap wifi
Not for a cheap £30 mass produced ISP router it isn’t.
  • 3.65K
  • 285
  • 514
Superfast
Message 7 of 8
Re: Crap wifi
Maybe your device is moving from 5Ghz to 2.4Ghz the further away it is?
Access your HUB on http://192.168.0.1 , access the 'Connected devices' section on the left hand side, and check what 'Speed (Mbps)' your device is connected at when 5 metres away from the HUB and right next to it.
Message 8 of 8
Re: Crap wifi
Grandson has been round done some tinkering and improved for me To 75Mbs. I’m now happy.
Thankyou to all who contributed
