Wzht2505
Continuous red light on router
My router has a constant red light. I have restarted it and reset it and it is still solid red. It went green initially after the reset and then back to red. Please can someone help? Do I need a new router?
  • 6.82K
  • 593
  • 1.79K
Re: Continuous red light on router
A persistant red LED after a power cycle is a failing overheat warning.  The Hub should be replaced by VM.
If you wait here a day or two a VM Mod will pick this up and arrange.
Paul_DN
  • 10.71K
  • 546
  • 1.09K
Hi Wzht2505,
Thank you for reaching out to us in our community and welcome, sorry to hear you have a solid Red light on your Router after a power cycle, I was able to locate you on our system with the details we have for you and cannot see any issues, if you still have a Red light I will be happy to help, I will send you an invite into a private chat, if needed click on the purple envelope to accept.
Paul.
