WingedSnake
  • 7
Message 1 of 11
Continue packet loss and Hub disconnects
My broadband is completely unusable for everybody on the house, no matter if connected through WiFi or ethernet as I am. We get lot's of T3 timeouts and pre rs errors, and I only have one channel for downstream and one for upstream. I checked regularly for the last two weeks the service status on my area, but they always say there is no problem.
https://www.thinkbroadband.com/broadband/monitoring/quality/share/b7be4d2e2c34f823538e73d3cfef968fe4f3e1f3-19-04-2021
363000000
Locked
Ranged Upstream Channel (Hz)
32600660
Locked
Provisioning State
Online
136300000011.640256 qam29
1Locked40.9370
13260066042.3512016 qam5
1ATDMA00990
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
cmreg-vmdg505-bbt060+voc-b.cm
SFID142718
Max Traffic Rate230000061
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID142717
Max Traffic Rate22000061
Min Traffic Rate0
Max Concatenated Burst42600
Scheduling TypeBestEffort
15/04/2021 22:15:16criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/04/2021 22:04:17Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/04/2021 01:24:45criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/04/2021 01:23:46criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/04/2021 01:19:30Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/04/2021 01:19:27criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/04/2021 01:19:26Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/04/2021 08:22:51criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/04/2021 03:13:20ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/04/2021 19:07:42criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/04/2021 18:04:30ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/04/2021 08:01:0criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/04/2021 23:22:11ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/04/2021 20:02:31criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/04/2021 11:22:11ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/03/2021 04:44:18criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/03/2021 23:22:11ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/03/2021 11:34:18criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/03/2021 19:21:57ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/03/2021 02:20:41criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
lotharmat
  • 937
  • 70
  • 142
Well-informed
Message 2 of 11
Re: Continue packet loss and Hub disconnects
Those are awful stats!
I would:
1. Check all connections are finger tight!
if that doesn't improve things:
2. Reset the hub - Pinhole reset - disconnect any ethernet cables and hold in the reset button with a paperclip or similar for at least 60 seconds
Allow it all to come back on (if it does) - COuld take 10 minutes.
Check again and if that doesn't improve things - VM would need to book a technician visit!
WingedSnake
  • 7
Message 3 of 11
I forgot to mention I already tried the pinhole reset and reconnect all cables. I will try to contact VM then.
Tags (1)
lotharmat
  • 937
  • 70
  • 142
Well-informed
Message 4 of 11
They will pick it up on here shortly!
WingedSnake
  • 7
Message 5 of 11
That is nice, I would really love to avoid contacting the customer service line.
lotharmat
  • 937
  • 70
  • 142
Well-informed
Message 6 of 11
That can be quite fraught! - And they'll likely tell you that all your woes will be cured by a magic speed increase --> Another 18 month contract --> More money!
WingedSnake
  • 7
Message 7 of 11
Updating BQM :
https://www.thinkbroadband.com/broadband/monitoring/quality/share/d1ed12263d5fd371cf0819088511a30a2d44ab4e-20-04-2021
lotharmat
  • 937
  • 70
  • 142
Well-informed
Message 8 of 11
That does look borked beyond belief!
WingedSnake
  • 7
Message 9 of 11
I know right? Something's terribly wrong, and I hope VM sees it soon.
Hayley_S
  • 545
  • 20
  • 47
Message 10 of 11
Hello @WingedSnake,
Welcome to the community page, thank you for posting on here.
I am sorry that your internet has not been working for you and your household.
I am unable to locate your account using your forums details, I would like to help you further, I will send you a private message so we can do this together.
Look forward to hearing back from you.
Hayley
