on 27-06-2021 15:07
Hi, I have had an engineer come by and change some wires but I still have the problem of intermittent wifi; the wifi slows down, the router reboots and at first displays red wifi lights, then 3 green lights. It then starts after a couple of minutes.
This is on all devices, over wifi, and happens approximately 10-15 times a day at this point.
A principle engineer will be visiting, but this required a lot of talking as everyone on the call centres claims there is no fault.
Here are my logs:
https://www.thinkbroadband.com/broadband/monitoring/quality/share/1b530d3fcbd447b1ff6d4df9abee08a3b1cd83a7
on 24-07-2021 15:55
Hi Fordxman5,
Thanks for getting back to us, I am sorry to hear you are having issues and the replacement or re-pull did not help.
What did the tech advise when he was there for the visit?
Zoie
on 24-07-2021 15:58
on 24-07-2021 16:25
I have checked your account it all looks okay, and I checked the latency in the area and there are no issues there either.
Is the service intermittent and unusable? Your BQM suggests that it lost connection to the hub, have you set up a new one with your hub replacement?
Has any of your tech visits helped the service at all?
Zoie
on 24-07-2021 16:35
on 24-07-2021 16:36
If its just wifi then look at getting your own better wireless router with 1Gb ports and put the hub in modem mode.
27-07-2021 12:00 - edited 27-07-2021 12:01
on 27-07-2021 12:22
Hi fordxman5,
Thanks for posting your BQM. Unfortunately upon checking your account just now, you are being affected by an area fault currently until 3pm this afternoon.
Due to this we are unbale to carry out further checks until issues has been resolved. I have raised a fault ticket on your account relating to this issue.
Please can we ask if you could kindly come back to us after 3pm this afternoon and we can continue diagnostics and take from there.
Kind regards Jodi.
on 27-07-2021 12:31
Has this fault been around for 40 days?
on 27-07-2021 12:54
Thanks for coming back to us fordxman5.
We appreciate you need this issue addressing and we certainly will for you, however until this area fault has been resolved today, it will not let us carry out any further diagnostics on your account.
Unfortunately the system thinks that you are being affected by this issue not an individual fault.
If you are able to wait until the estimated fix time of 3pm today, we will happily investigate the issue for you.
Kind regards Jodi.
on 27-07-2021 20:20
Just went out again, problem not fixed 😀
