Constant wifi drops
HayanButt
Not been a part of virgin media but have been experiencing wifi drops,
Called customer service, they said they would send a boost to the hub, fixed the solution for about a day then went back to dropping out
Did the customer service whatsapp chat, reset my hub again and nothing happened
I work from home I can't keep having these drop outs
I can't even make an appeal because when the wifi is on the speeds are within the promised speed range, but speed is not the issue
Please help me fix this ASAP
2 REPLIES 2
See this as a starter...
__________________
Do you know if its a wifi only issue (ethernet connections are ok?), if it is - then On a Hub3/4/5, you could first try separating the SSID's of the 2.4 and 5 GHz wifi bands by renaming them in the settings At the same time switch off "channel optimisation/Smart wifi” and “ apply and save the settings. All wifi devices will now need reconnecting to the best SSID at each location. Also use a wifi scanning App to find the best wifi channels to use (just select and use channels 1,6,11 on 2.4GHz) - this often helps Hub users get better wifi performance - so its worth trying - but its still no substitute for getting better kit 🙂
To address the wifi issues, VM now supply “wifi Pods” (no longer doing cheap and cheerless and poor value “boosters”). However, their Pods are only free to customers on the 1GB, Volt (or old Ultimate Oomph) packages - is that you? If so they are worth trying - they should work for you. VM Wifi is now “guaranteed” to 20 Mbps/room it’s now called… Wifi Max
https://www.virginmedia.com/help/wifi-max
You call 0800 064 3850 to order the first one after scanning for blackspots using the connect App.- or just wait here for a VM person to respond in a day or two and they will sort the first one for you. If you do call dont get fobbed off by the offshore CS agents' saying you aren’t eligible it will be £5 or £8 month - you are… and it wont be - just look on the webpage.
If not free to you… you will be charged £8/month (note - BT charge £10/mo for their whole home wifi solution). It’s a simple solution and should work for you. However, you would soon pay off that cost by buying your own wireless solution that will be yours to own and use forever, although the VM Pods should be a simpler option.
If you do want to invest in better equipment, you would need to get either a… (1) Mesh System, (2) Wireless router, (3) Wireless access point (4) A combination of (2,3).
£30-100 (that’s ~4->12 months of Max Pod rental) should sort it for most customers with an average property and usage.
Ryan_N
Hi HayanButt,
Thank you for your post and welcome to the forums.
I am sorry to hear of the experience you've been having here - I can only appreciate how frustrating it must be. I have been able to check things from our side and can see there is a couple of things that need checking over. I will send you a private message to confirm some details with you.
Cheers,
Ryan.
