Constant red light
Vkb1
I’ve seen that a few people have had the same issues so apologies for repeating however our superhub 3.0 has been showing a solid red light for months now. Our wifi connections are temperamental, sometimes it’s fine, sometimes it hardly works at all. I’ve checked that the cables are all connected, it’s in router mode and I’ve rebooted it several times. Can anyone help please?
Many thanks
Victoria
5 REPLIES 5
Vkb1
Many thanks
Victoria
Please do a pin hole reset of you Hub3 (it’s not a SuperHub) and if the red LED persists, the hub will need replacing. Please report back.
Please do a pin hole reset of the hub. If the red LED persists it will need replacing.
Joseph_B
Hey @Vkb1,
Welcome to the Community Forums and thanks for the post.
Sorry to see you have this issue with your Hub, to go about fixing this I would like to send out a technician to review this with you, for me to do so I will need to confirm some information in a quick private message, which I will be sending to you now.
Joe
Hey Vkb1, thank you for reaching out and a warm welcome to the community I am so sorry to hear this.
I am going to send you a PM but please can you try these steps in the meanwhile;
• Then use the power switch to turn the unit back on. The Hub should now operate normally.
Cheers
Matt - Forum Team
New around here?
