Constant red light on. Hub
Seaneen81
I have had a constant red light on my hub for two weeks or more now. I have reset and rebooted numerous times and the red light just won’t go. The connection has been very intermittent too. Tried to get onto WhatsApp to chat to customer services but I’m waiting along time now? Thanks in advance
Seaneen
2 REPLIES 2
If the red LED is still on after a pinhole reset, and it's a Hub 3, it will need replaced.  That's the overheat warning for the Hub 3 and as such should be working correctly, or it is a risk.
If you wait here a day or two a VM Mod will pick this up and discuss.
Thank you
