  • 162
  • 16
nad223
Dialled in
Constant drop outs on wired and wireless connection
My hub 3 loses all connection between 10+ times a day for between 5 minutes and beyond I've spoken to technical support over 50 times. I've had 25+ engineers to my property. If you look at my account this issue has been on going since the past year and this time I will not be leaving Virgin Media as I have no where else to go to as you're the only provider offering fibre in my area.
08/04/2019 09:40:7 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/04/2019 09:40:7 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/04/2019 09:40:8 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/04/2019 09:40:8 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/04/2019 09:40:13 Warning! Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/04/2019 09:40:55 critical Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/04/2019 09:52:11 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/04/2019 13:16:4 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/04/2019 13:16:4 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/04/2019 13:16:5 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/04/2019 13:16:5 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/04/2019 13:16:10 Warning! Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/04/2019 13:17:2 critical Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:03:51 Error Missing Mandatory MDD TLV on primary DS Channel;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/04/2019 13:33:44 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/04/2019 14:29:8 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/04/2019 14:29:9 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/04/2019 14:29:9 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/04/2019 14:29:12 Warning! Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
1 187000000 8.3 38 256 qam 7
2 195000000 7.9 38 256 qam 8
3 203000000 7.5 37 256 qam 9
4 211000000 7.3 38 256 qam 10
5 219000000 7 38 256 qam 11
6 227000000 7 37 256 qam 12
7 235000000 6.5 37 256 qam 13
8 243000000 6.3 37 256 qam 14
9 251000000 6 37 256 qam 15
10 259000000 5.8 37 256 qam 16
11 267000000 5.6 38 256 qam 17
12 275000000 5.4 38 256 qam 18
13 283000000 5.4 38 256 qam 19
14 291000000 5.4 38 256 qam 20
15 299000000 5.3 38 256 qam 21
16 307000000 5 38 256 qam 22
17 315000000 5.3 38 256 qam 23
18 323000000 5.1 38 256 qam 24
19 379000000 4.6 38 256 qam 25
20 387000000 4.6 38 256 qam 26
21 395000000 4.6 38 256 qam 27
22 403000000 4.5 37 256 qam 28
23 411000000 4.5 37 256 qam 29
24 419000000 4.5 37 256 qam 30
1 Locked 38.6 5 0
2 Locked 38.6 4 0
3 Locked 37.6 5 0
4 Locked 38.6 6 0
5 Locked 38.9 6 0
6 Locked 37.6 7 0
7 Locked 37.6 4 0
8 Locked 37.6 0 0
9 Locked 37.6 0 0
10 Locked 37.6 0 0
11 Locked 38.6 6 0
12 Locked 38.6 0 0
13 Locked 38.6 12 0
14 Locked 38.6 5 0
15 Locked 38.6 5 0
16 Locked 38.9 5 0
17 Locked 38.9 5 0
18 Locked 38.6 5 0
19 Locked 38.6 6 0
20 Locked 38.6 5 0
21 Locked 38.6 4 0
22 Locked 37.6 7 0
23 Locked 37.6 5 0
24 Locked 37.6 0 0
1 46200109 3.85 5120 64 qam 1
2 25799961 3.65 5120 16 qam 4
3 32600192 3.7 5120 16 qam 3
4 39399974 3.7 5120 16 qam 2
1 ATDMA 0 0 0 0
2 ATDMA 0 0 0 0
3 ATDMA 0 0 0 0
4 ATDMA 0 0 0 0
  • 6.42K
  • 493
  • 1.07K
Hero
Re: Constant drop outs on wired and wireless connection
Stats are all ok except 3 upstream channels with 16QAM when they should be 64QAM. I suspect noise ingress. You should phone customer services and report the problem, they should be able to advise if there are any local problems and perhaps arrange a technician.
  • 162
  • 16
nad223
Dialled in
Eirum at 13:01, Apr 17: As per the update received, the network fault is estimated to be fixed on the 22/4/19 at 1500 hrs.
  • 162
  • 16
nad223
Dialled in
the fault keeps getting extended this is getting beyond a joke since start of april and we're almost into may they should just extend it to 2020 at this rate
  • 6.42K
  • 493
  • 1.07K
Hero
Network faults, often those caused by noise ingress, are extremely difficult to fix. Unfortunately it can some time, as it not like a broken cable when either you have a service or you do not.
  • 162
  • 16
nad223
Dialled in
fault extended to the 4th of june Smiley Sadvirgin media keep extending
