Constant Red light on HUB
rav_11
My Hub is showing a constant red LED.  I have tried all the resets and restarts listed on the forum and it is still a solid red light.
The hub is running in modem mode connected to a TP link wifi 6 router. I have a connection to the internet at full speed . I am concerned that the hub is about to fail as I have had it for a number of years
Any help would be appreciated
1 ACCEPTED SOLUTION
Accepted Solutions
Good Evening @rav_11, thanks for your follow up post.
Check out the purple envelope in the top right hand corner for a private message from me, and I'll have the hub replaced for you.
Kindest regards,
David_Bn
11 REPLIES 11
In modem mode - the Hub3's light is meant to be "magenta" - this looks bright red to many eyes.
rav_11
Thanks for the reply John,
I may be getting on a bit but I am certainly not colour blind, like you pointed out it is supposed to be Magenta!!!!!! how ever it is  RED. To me that means a problem .
I know when I put the TP link router in it was off white. After doing all the reset's etc yesterday I noticed a marked delay in connecting to the network.
Flick the Hub back to normal router mode for a few minutes and see if the light stays "red" or turns to normal white white. That will indicate what course of action is needed
A VM person has been alerted and will be along soon
Hi rav_11,
Thank you for reaching back out, can you put our Router back in Router mode by performing a pin reset, if the hub goes back to white then we know it was just because it was in Modem Mode.
Paul.
Hi Paul
I dare not do a pin reset because I cannot get into the router admin setting too reset to modem mode.I did find a poor connection on the network input cable from the street. I have remade the connection and rebooted the hub . Everything is working apart from the red light on the hub and admin rights on the router. I am getting full band width up and down.
unisoft
Knows their stuff
So if the light was white, would be OK. Accepted. So, if one has a red light when using modem mode, how does one ever tell its hot and overheating then if that's the normal colour light all the time??? In short, there is no way to check as the only method that would indicate an issue is to leave the router in router mode and not use modem mode. Modem mode was always magenta, and some VM reps have gone on to say (including to me last year) that RED was the new Magenta. I'm not colour blind either and got good colour recognition.
Totally agree, It appears to me that the router is on the way out. I have had it a good number of years. What concerns me is the safety side of things. Heaven forbid it catches fire!!!
I do not understand why they will not just send me a new hub.
Kindest regards,
David_Bn
Thanks for working with me via our private messaging function @rav_11 and I'm pleased we were able to make positive strides forward on this one.
Do please keep us updated with how the engineer visit goes, with hub swap goes.
Kindest regards,
David_Bn
