  • 6
Message 1 of 13
Constant Packet Loss
Hi, I hope this is the right place to post this.
Over the past year or so I've been experiencing a constant packet loss issue. It's taken me nearly a year to get to the point where I'm certain that's what it is. I stream on Twitch and am not sure what to do from here as it's starting to seriously affect the Channel.
https://www.thinkbroadband.com/broadband/monitoring/quality/share/1fe860cb9887e17bbad204d869055f461f...
I've ran a BMQ, I think that's what it's called, and it will consistently drop packets at random intervals which cuts the stream and is now massively affecting the viewer experience.
Obligatory, I've already tried restarting the modem, setting back to factory settings, using a different ethernet cable and making sure all connections are nice and snug.
If anyone could help I'd owe you my sanity.
Thanks.
EDIT - This does also affect lagging out in games and the occasional moment of buffering but the stream is way more of a priority.
Tags (3)
  • 20.96K
  • 1.14K
  • 2.7K
Message 2 of 13
Re: Constant Packet Loss
Post the network, upstream and downstream logs from the hub admin pages
  • 6
Message 3 of 13
Hi Gary, thanks for the quick response. It's a lot of text and I don't really know how to format it so I hope dumping it here makes sense.
Network:
23/06/2020 13:35:5noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/06/2020 13:34:27Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/06/2020 11:57:27ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/06/2020 16:01:31criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/06/2020 15:46:41ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/06/2020 14:59:15ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/06/2020 14:15:50criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/06/2020 14:30:30ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/06/2020 14:37:41criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/06/2020 17:51:28ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/06/2020 11:34:35ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/06/2020 09:06:50criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/06/2020 16:44:8ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/06/2020 22:34:6criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/06/2020 20:37:23ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/06/2020 19:19:57ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/06/2020 03:28:3criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/06/2020 22:36:20ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/06/2020 10:03:20ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/06/2020 07:57:53criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
I'm assuming you didn't want the Upstream and Downstream bonded channels and they don't seem to say anything? If you do I can post those too. 🙂
  • 20.96K
  • 1.14K
  • 2.7K
Message 4 of 13
Yes the upstream and downstream tabs too please
  • 6
Message 5 of 13
:') My apologies.
Downstream:
1138750000-4.237256 qam1
2146750000-4.437256 qam2
3154750000-4.237256 qam3
4162750000-4.237256 qam4
5170750000-4.237256 qam5
6178750000-4.537256 qam6
7186750000-4.937256 qam7
8194750000-4.237256 qam8
9202750000-3.937256 qam9
10210750000-3.737256 qam10
11218750000-438256 qam11
12226750000-437256 qam12
13234750000-437256 qam13
14242750000-3.937256 qam14
15250750000-3.737256 qam15
16258750000-3.737256 qam16
17266750000-3.237256 qam17
18274750000-3.437256 qam18
19282750000-3.437256 qam19
20290750000-3.537256 qam20
21298750000-337256 qam21
22306750000-2.738256 qam22
23314750000-2.737256 qam23
24322750000-337256 qam24
1Locked37.6923434084
2Locked37.6868222396
3Locked37.6574330720
4Locked37.6465733290
5Locked37.6431633680
6Locked37.3434929870
7Locked37.6462828672
8Locked37.3366829074
9Locked37.6577324985
10Locked37.6379428042
11Locked38.6412525665
12Locked37.6488227866
13Locked37.6452425258
14Locked37.3486625753
15Locked37.6472125852
16Locked37.6503025684
17Locked37.6578418740
18Locked37.6491824341
19Locked37.6589723537
20Locked37.6514023348
21Locked37.6581330420
22Locked38.6470933363
23Locked37.6445930163
24Locked37.6503324201
Upstream:
1462000004.075512064 qam1
2258000004.204512064 qam4
3394000004.15512064 qam2
4326000004.175512064 qam3
3ATDMA0000
4ATDMA0000
  • 20.96K
  • 1.14K
  • 2.7K
Message 6 of 13
When was the hub last rebooted?
  • 6
Message 7 of 13
As in a simple power cycle?
Probably about a few months ago?
I stopped rebooting it during problem periods as it hadn't worked for all the other times I had tried it.
  • 20.96K
  • 1.14K
  • 2.7K
Message 8 of 13
Reboot it again now and repost the stats again in an hours time.
The Post RS levels should be zero not in the thousands they are now so hoping it just historical data.
Also I’m surprised the hub has lasted a few “months” without a reboot as they usually have to have a kick every couple of weeks.
  • 6
Message 9 of 13
Power cycled it and left it off for a minute before powering back on just to make sure it had a chance to shut down properly.
I'm also assuming that I didn't reboot it for a few months and I don't remember doing it since we've been in lockdown in the UK, I could definitely be wrong about that. 🙂
1194750000-437256 qam8
2202750000-3.737256 qam9
3210750000-3.537256 qam10
4218750000-3.937256 qam11
5226750000-437256 qam12
6234750000-437256 qam13
7242750000-3.737256 qam14
8250750000-3.737256 qam15
9258750000-3.737256 qam16
10266750000-3.237256 qam17
11274750000-3.237256 qam18
12282750000-3.237256 qam19
13290750000-3.437256 qam20
14298750000-337256 qam21
15306750000-2.738256 qam22
16314750000-2.537256 qam23
17322750000-2.937256 qam24
18402750000-1.938256 qam25
19410750000-1.538256 qam26
20418750000-1.438256 qam27
21426750000-0.938256 qam28
22434750000-138256 qam29
23442750000-0.938256 qam30
24450750000-0.738256 qam31
1Locked37.360
2Locked37.650
3Locked37.640
4Locked37.650
5Locked37.660
6Locked37.650
7Locked37.660
8Locked37.630
9Locked37.650
10Locked37.660
11Locked37.350
12Locked37.650
13Locked37.640
14Locked37.660
15Locked38.650
16Locked37.660
17Locked37.600
18Locked38.960
19Locked38.940
20Locked38.650
21Locked38.940
22Locked38.600
23Locked38.950
24Locked38.950
2258000004.2512064 qam4
3326000004.175512064 qam3
4394000004.15512064 qam2
3ATDMA0000
4ATDMA0000
I didn't include the Network log as literally nothing has changed.
  • 6.08K
  • 310
  • 539
Message 10 of 13
Hi Tubbzie
Thanks for posting and welcome to the community. My apologies for the broadband issues. I've checked the system today and no issues are showing so I do hope everything is resolved. Please keep me posted should you need further assistance.
Kind regards,
John_GS
