  • 17
Constant Drop of Connection
So I've been having these troubles for over a month now. And it is just steadily getting worse and worse. I've had an engineer round to try and fix my line of which helped for all but a day (My line had been messed with, and installed incorrectly with old hardware, some of that down to myself).
Basically it seems that every time I boot up my PC (or any first time new connection) my router tries to send out a DHCP Renew Request, that does not work. Sometimes accompanied by a "No Ranging Response" error. It will disconnect, and reconnect over a few minutes (first started with only happening once every 2 days, for a minute, to being full blown every day almost with it lasting nearly 10 minutes sometimes).
Personally, I feel this might be my Router giving up. The previous fix was done due to too much power being put through the line, and I feel this might have caused some damage to the Router itself.
I've tried soft, and hard restarting. Resetting. Different power sockets. Using different LAN ports. Different cables. Nothing works.
  • 17
Re: Constant Drop of Connection
07/04/2020 22:33:44noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/04/2020 09:36:44ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/04/2020 07:43:23criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/04/2020 17:51:43ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/04/2020 04:50:14criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/04/2020 18:05:59noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/04/2020 01:01:3criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/04/2020 22:24:47noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:32criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/04/2020 22:19:43noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/04/2020 20:11:27criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/03/2020 21:52:12ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/03/2020 00:53:22ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/03/2020 21:10:25noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/03/2020 14:49:0criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/03/2020 13:30:17noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/03/2020 01:08:59criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/03/2020 19:57:54ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/03/2020 12:27:30ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/03/2020 08:27:2criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
  • 17
1393999194.325512064 qam4
2462001174.35512064 qam3
3536999774.425512064 qam2
4603000004.425512064 qam1
3ATDMA0000
4ATDMA0000
11390000006.838256 qam1
2147000000738256 qam2
3155000000738256 qam3
41630000007.138256 qam4
51710000007.338256 qam5
61790000007.138256 qam6
71870000007.538256 qam7
81950000007.538256 qam8
92030000007.538256 qam9
102110000007.438256 qam10
112190000007.138256 qam11
122270000007.538256 qam12
132350000007.438256 qam13
142430000007.138256 qam14
152510000007.840256 qam15
162590000007.938256 qam16
172670000008.140256 qam17
182750000008.538256 qam18
192830000008.340256 qam19
202910000008.638256 qam20
212990000008.938256 qam21
223070000008.540256 qam22
23315000000940256 qam23
243230000009.140256 qam24
1Locked38.91420
2Locked38.95500
3Locked38.62150
4Locked38.9690
5Locked38.61340
6Locked38.91060
7Locked38.6290
8Locked38.9710
9Locked38.6490
10Locked38.91900
11Locked38.9530
12Locked38.9440
13Locked38.9360
14Locked38.9780
15Locked40.3400
16Locked38.94400
17Locked40.31260
18Locked38.9440
19Locked40.9970
20Locked38.9410
21Locked38.6210
22Locked40.3650
23Locked40.3450
24Locked40.3780
