  • 8
Message 1 of 5
Constant Disconnections and packet loss
I have been experiencing constant issues with my hub for the last month. This is after 3 days of uptime since the last reset. Could anyone advise what I should do as working from home is becoming very tricky!
Thanks!
12030000001.538256 qam9
22110000001.738256 qam10
32190000001.736256 qam11
42270000001.437256 qam12
52350000001.238256 qam13
62430000001.538256 qam14
72510000001.238256 qam15
82590000001.538256 qam16
92670000002.238256 qam17
10275000000238256 qam18
112830000002.238256 qam19
122910000002.238256 qam20
132990000002.238256 qam21
143070000002.238256 qam22
15315000000238256 qam23
163230000002.238256 qam24
173630000001.238256 qam25
183710000001.238256 qam26
19379000000138256 qam27
203870000000.938256 qam28
213950000000.938256 qam29
22403000000138256 qam30
23411000000138256 qam31
244190000000.738256 qam32
1Locked38.937801845
2Locked38.9856421330
3Locked36.390037908
4Locked37.347274481
5Locked38.64804177
6Locked38.957617499
7Locked38.642884540
8Locked38.618766314
9Locked38.615351153
10Locked38.91919543
11Locked38.616091101
12Locked38.615717135
13Locked38.6731912
14Locked38.6411530
15Locked38.6422635
16Locked38.6313620
17Locked38.9308036
18Locked38.627153
19Locked38.91568695
20Locked38.9106174
21Locked38.66790
22Locked38.614110
23Locked38.612350
24Locked38.67380
15369998148.3512064 qam2
26030000049.3512064 qam1
33939997147.5512064 qam4
44620000048.5512064 qam3
1ATDMA0010
2ATDMA0020
3ATDMA0030
4ATDMA0000
Image of a broadband quality monitor.
  • 12.22K
  • 947
  • 1.57K
Message 2 of 5
Re: Constant Disconnections and packet loss
Your Pre & Post RS Error counts are very high.
In an ideal world they would be at zero and stay there. To zero them can you reboot the Hub using this method and then keep an eye on the counts.
Switch the Hub off using the small switch on the rear of the Hub next to the power cord and pull the PSU plug from the wall socket.
Give it a good 5 minutes put the plug back in and switch the Hub back on.
Allow the Hub a few minutes to fully restart then check the counts again in an hour or so.
Mike Robinson
  • 12.22K
  • 947
  • 1.57K
Message 3 of 5
Mike Robinson
  • 8
Message 4 of 5
Thanks, mike for your help. Here is the BQM from the last couple of days
https://www.thinkbroadband.com/broadband/monitoring/quality/share/d085c339ce5b52249cd1f9db4ddae3ac00...
  • 12.22K
  • 947
  • 1.57K
Message 5 of 5
Your >> BQM << is showing that you have been hyper busy uploading and downloading or you are in a very busy area that is verging on over utilisation.
You can phone in and complain about the Constant Disconnections and packet loss (08:00 is the best time) or wait on here for a few days (6 to 7 days average) until one of the VM Forum Staff comes along.
Mike Robinson
