expatista
  • 37
Connectivity issues over wired connection HUB log files pasted below
Would appreciate if someone could look at this for me.  I have switched to a wired connection and have connectivity issues on the wired connection too!  I have critical errors in the hub's log file, been rebooting and factory resetting the hub on a daily basis.  Can one buy a third part hub to use in modem mode or does that piece of equoipment need to be from VM?  I have just received my Deco M4 but that is for WiFi.
Upstream and downstream logs below.
Time
Priority
Description
25/01/2021 12:02:47
notice
LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/01/2021 07:10:1
critical
23/01/2021 15:55:33
Warning!
RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/01/2021 15:55:33
critical
SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/01/2021 14:00:2
Warning!
23/01/2021 14:00:2
critical
23/01/2021 11:22:50
Warning!
23/01/2021 11:22:50
critical
23/01/2021 11:03:57
Warning!
23/01/2021 11:03:57
critical
23/01/2021 07:33:25
Warning!
23/01/2021 07:33:24
critical
23/01/2021 07:23:54
Warning!
23/01/2021 07:23:54
critical
23/01/2021 07:19:39
Warning!
23/01/2021 07:19:39
critical
23/01/2021 06:47:16
Warning!
23/01/2021 06:47:16
critical
23/01/2021 06:47:15
Warning!
23/01/2021 06:47:15
critical
Channel
Frequency (Hz)
Power (dBmV)
SNR (dB)
Modulation
Channel ID
1
474250000
6.3
38
256 qam
9
2
482250000
6.1
40
256 qam
10
3
490250000
6.4
38
256 qam
11
4
498250000
6
38
256 qam
12
5
506250000
5.6
38
256 qam
13
6
514250000
5.6
38
256 qam
14
7
522250000
5.6
38
256 qam
15
8
530250000
5.8
38
256 qam
16
9
538250000
5.6
38
256 qam
17
10
546250000
5.6
38
256 qam
18
11
554250000
5.8
38
256 qam
19
12
562250000
6
38
256 qam
20
13
570250000
6
38
256 qam
21
14
578250000
6
38
256 qam
22
15
586250000
6.3
40
256 qam
23
16
594250000
5.6
38
256 qam
24
17
658250000
5.5
38
256 qam
25
18
666250000
5.9
38
256 qam
26
19
674250000
6
38
256 qam
27
20
682250000
6.1
38
256 qam
28
21
690250000
6.4
38
256 qam
29
22
698250000
6.3
38
256 qam
30
23
706250000
6.5
40
256 qam
31
24
714250000
6.5
38
256 qam
32
Channel
Locked Status
RxMER (dB)
Pre RS Errors
Post RS Errors
1
Locked
38.9
678
0
2
Locked
40.3
672
0
3
Locked
38.9
678
0
4
Locked
38.9
831
0
5
Locked
38.9
924
0
6
Locked
38.9
1019
0
7
Locked
38.6
1017
0
8
Locked
38.9
966
0
9
Locked
38.9
1112
0
10
Locked
38.9
1393
0
11
Locked
38.9
1418
0
12
Locked
38.9
1243
0
13
Locked
38.6
1318
0
14
Locked
38.9
1462
0
15
Locked
40.9
1155
0
16
Locked
38.9
1268
0
17
Locked
38.9
1127
0
18
Locked
38.9
1234
0
19
Locked
38.9
1129
0
20
Locked
38.9
1001
0
21
Locked
38.9
879
0
22
Locked
38.9
864
0
23
Locked
40.3
632
0
24
Locked
38.9
583
0
Channel
Frequency (Hz)
Power (dBmV)
Symbol Rate (ksps)
Modulation
Channel ID
1
46200088
45.8
5120
64 qam
1
2
25800000
46
5120
32 qam
4
3
32600000
46
5120
64 qam
3
4
39399965
45.8
5120
64 qam
2
Channel
Channel Type
T1 Timeouts
T2 Timeouts
T3 Timeouts
T4 Timeouts
1
ATDMA
0
0
0
0
2
ATDMA
0
0
0
0
3
ATDMA
0
0
0
0
4
ATDMA
0
0
0
0
expatista
  • 37
Re: Connectivity issues over wired connection HUB log files pasted below
forgot BQM and speedtest (Ihave the 100 package)
