Priingleton
  • 8
Message 1 of 17
Connectivity issue
For the last month or 2 i have noticed that i am not getting the speeds i pay for. i seem to get on average 100mb - 150mb download but pay for 600mb. I have rebooted my Virgin Hub 3 multiple times and my router multiple times, this fixes the issue for a couple of hours then the speeds drop again. Can anyone help?
Please find below my Virgin Hub 3 logs.
Status:
283000000
Locked
Ranged Upstream Channel (Hz)
39400029
Locked
Downstream:
1283000000340256 qam19
2139000000638256 qam1
31470000005.838256 qam2
41550000005.538256 qam3
51630000005.338256 qam4
61710000005.438256 qam5
71790000004.938256 qam6
81870000004.838256 qam7
91950000004.338256 qam8
102030000003.738256 qam9
112110000003.538256 qam10
122190000003.238256 qam11
13227000000338256 qam12
142350000002.738256 qam13
152430000002.438256 qam14
162510000002.238256 qam15
17259000000338256 qam16
18267000000338256 qam17
19275000000338256 qam18
202910000002.738256 qam20
212990000002.738256 qam21
22307000000338256 qam22
233150000002.938256 qam23
243230000002.538256 qam
24
Upstream:
13940002938.3512064 qam10
22580004136.3512064 qam12
33260000738.3512064 qam11
44619997138.3512064 qam9
Network Log:
25/06/2021 05:41:26criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/06/2021 10:50:36noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt078-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/06/2021 10:50:36ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/06/2021 08:32:58criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**:cf;CM-QOS=1.1;CM-VER=3.0;
20/06/2021 22:50:36noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt078-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/06/2021 22:50:36ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/06/2021 17:04:18criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**CM-QOS=1.1;CM-VER=3.0;
17/06/2021 10:08:27noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt078-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/06/2021 10:08:27ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/06/2021 07:41:49criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/06/2021 22:08:27noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt078-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/06/2021 22:08:27ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/06/2021 10:44:40criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/06/2021 10:08:27noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt078-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/06/2021 10:08:27ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/06/2021 05:21:36criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/06/2021 22:08:27noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt078-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/06/2021 22:08:27ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/06/2021 10:08:27noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt078-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/06/2021 10:08:27ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Any help will be much appreciated.
Andrew-G
  • 7.05K
  • 1.22K
  • 3.08K
Message 2 of 17
Re: Connectivity issue
I'm afraid there's nothing stands out in the hub status data - all figures and network log posted look OK, though you've not posted the second table of downstream data, and that might show something - in particular the post-RS error counts, which will be collected since the hub was last rebooted.
How are you measuring speed?
And you might want to setup a BQM over at https://www.thinkbroadband.com/broadband/monitoring/quality as that'll show if anything is going on with your VM connection.  Post a LINK to a LIVE, SHARED graph here and we'll see what's happening.  Usually needs to run for 24 hours before we can draw reasonable conclusions, but the live graph will continuously update so you can post the link immediately.
Priingleton
  • 8
Message 3 of 17
Please find my BQM below. (please note the red bars corresponed when i rebooted my modem and router)
https://www.thinkbroadband.com/broadband/monitoring/quality/share/dfbae07887ed85345faa6b934054d8fc89...
Ayisha_B
  • 1.46K
  • 50
  • 137
Message 4 of 17
Hi @Priingleton,
Welcome to our Community Forums and thanks for posting.
I am sorry to hear you are having issues with your service. Thanks for setting up the BQM and providing the link.
So that I can run some further tests, can you please pop the router out of modem mode please?
Cheers
Ayisha_B
Priingleton
  • 8
Message 5 of 17
Hi @Ayisha_B
My Virgin Hub is now inrouter mode for you to run some tests.
Many Thanks
jpeg1
  • 4.78K
  • 264
  • 773
Superstar
Message 6 of 17
Your BQM looks very good.
Just to confirm, since you haven't mentioned it, but your speed tests were done with an ethernet connection to your router?  You are probably aware that WiFi speeds are not guaranteed.
Priingleton
  • 8
Message 7 of 17
Yes, all tests have been done via ethernet. All devices in the house that support ethernet are using it only devices like phones and smart speakers are on wifi.
Many thanks
jpeg1
  • 4.78K
  • 264
  • 773
Superstar
Message 8 of 17
Have you checked the speed with a direct connection to the Hub rather than through your router?
Priingleton
  • 8
Message 9 of 17
I have, i get around 250mb down so a good improvment but not great for my package.
jpeg1
  • 4.78K
  • 264
  • 773
Superstar
Message 10 of 17
Certainly not.
As a last desperate measure you could try another ethernet lead.  They do fail sometimes.
