mcl73
Connectivity fluctuating wildly and dipping out altogether
I have been on Virgin Media for about a month having switched from EE as they were the only superfast provider in the area. I am beginning to regret it.  At its best, the connection is fast.  But it isn't at its best very often.  It regularly dips below 10mbps on download and will cut out altogether at times.  I have tested all rooms around the house and the signal is strong.  Have rebooted, factory reset etc. A reboot will often solve the issue but it doesn't hold and I am having to reset the box at least once per day.  It is useless on Teams and Zoom to keep having these fluctuations.  I am running a large business from home and this is not a good advert for VM to my colleagues.  I have followed all the help lines and am still trying to get through to speak to a human being!
Here is a printout of my speedchecks to give a sense of the issue.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.93K
Re: Connectivity fluctuating wildly and dipping out altogether
What speeds do you get at >>  SamKnows << with a direct connection using a Cat 5E or better ethernet cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
Then immediately after …
Login to the Hub Settings and navigate to the Connected Devices page - what is the reported 'connection speed’ for the ethernet cable connected device you used for the speed test ?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.93K
A bit more information is required, please post the following ...
Please do this before posting the Hub Data
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.93K
Can you please
Hub 4 When the page appears LOG IN then Advanced Settings > Tools > Network Status.
Please do not use screen shots.
Copy and paste the contents of the Downstream, Upstream, Configuration and Network Log tabs onto here, if you get a yellow / straw box warning click the Post button again.
Use one post for each tab if you wish.
