on 09-11-2023 08:45
I have been experiencing connectivity issues for a few days now, but last night it became much worse.
I have a gig1 connection. I have been running a BQM from thinkbroadband since last night.
can anyone help please
thanks
on 09-11-2023 14:17
See this...
Can we check… are your issues only evident on wifi connections or do you see them at the same times on devices connected on ethernet cables? If you don't know, can you check to help diagnose whether it is just a wifi issue or it could be network connection/Hub related?
Post up the link to the BQM - "share live graph".
on 09-11-2023 14:41
thanks for the reply - please see for the graph:
https://www.thinkbroadband.com/broadband/monitoring/quality/share/922eb268c2f7e2be895d336ccd34b4110bfde1eb
I’m actually running most of connections wired, and I’m running a centrally managed Wi-Fi system through 3 ceiling mounted WiFi access points so the hub is running in modem mode into the gateway. The gateway is currently droppping ICMP ping packets as it believes it to be an attack, hence the graph showing 100% packet loss - I will rectify this when I’m back home later.
The issue is both WiFi and wired, it’s definitely an upstream issue.
09-11-2023 14:49 - edited 09-11-2023 14:52
EDIT: Sorry missed reading the bottom of your post re. pings ! got distracted by the BQM 😎
The BQM is a wall of red! Can be for several reasons.
Your network connectivity has gone - so check for any “known network faults in your location - Look in 2 places
1) Try the “check service,”Area status webpage (https://www.virginmedia.com/help/service-status)
2) Then also Try the “free & automated” Service Status number - 0800 561 0061 - which usually gives the most up to date info. and tells you of more local issues and fix estimates, down to street cab/ postcode level.
OR... your ip address may have changed - so check what it is and its the same as in the BQM settings page
OR... your router has stopped responding to echo requests (pings) - are you using your own router or the VM Hub's router? Check that any "allow/respond to pings/echo requests" box is ticked (yes you are!)
on 09-11-2023 14:55
To follow on....
If there are no known issues, Post up your Hub/network connection details and someone will check to see if there is a problem there. In your browser’s URL box type in http://192.168.0.1 (or http://192.168.100.1 - if in modem mode) (DONT click these links) - and hit return. No need to log in - just click on the “Router Status” icon/text at bottom-middle of the Login page.
Then… Navigate to these “data pages” and just copy/paste the normal “Formatted Text” (not images) 3 FULL sets of data onto here – 2 tables from the Downstream, 2 from the Upstream, & the Network Logs pages. Don't worry too much about the formatting it can be easily read & DON’T include personal data or MAC addresses - blank them out - if you copy/paste the data, the board software will do this for you (you may need to click the "submit" button again). If character limits are “exceeded” - just do two posts
on 09-11-2023 17:40
Thank you
Here is the output:
Downstream:
3.0 Downstream channels
1 | 331000000 | 14.9 | 39 | QAM 256 | 25 |
2 | 139000000 | 16.5 | 39 | QAM 256 | 1 |
3 | 147000000 | 16 | 39 | QAM 256 | 2 |
4 | 155000000 | 15.6 | 39 | QAM 256 | 3 |
5 | 163000000 | 15.3 | 39 | QAM 256 | 4 |
6 | 171000000 | 15.2 | 39 | QAM 256 | 5 |
7 | 179000000 | 14.9 | 39 | QAM 256 | 6 |
8 | 187000000 | 14.5 | 39 | QAM 256 | 7 |
9 | 195000000 | 14.1 | 39 | QAM 256 | 8 |
10 | 203000000 | 13.7 | 38 | QAM 256 | 9 |
11 | 211000000 | 13.8 | 38 | QAM 256 | 10 |
12 | 219000000 | 13.8 | 38 | QAM 256 | 11 |
13 | 227000000 | 13.7 | 39 | QAM 256 | 12 |
14 | 235000000 | 13.6 | 38 | QAM 256 | 13 |
15 | 243000000 | 13.6 | 38 | QAM 256 | 14 |
16 | 251000000 | 13.5 | 39 | QAM 256 | 15 |
17 | 259000000 | 13.3 | 38 | QAM 256 | 16 |
18 | 267000000 | 13.1 | 38 | QAM 256 | 17 |
19 | 275000000 | 13.1 | 38 | QAM 256 | 18 |
20 | 283000000 | 13.5 | 39 | QAM 256 | 19 |
21 | 291000000 | 14.3 | 39 | QAM 256 | 20 |
22 | 299000000 | 14.4 | 39 | QAM 256 | 21 |
23 | 307000000 | 14.5 | 39 | QAM 256 | 22 |
24 | 315000000 | 14.4 | 39 | QAM 256 | 23 |
25 | 323000000 | 14.7 | 39 | QAM 256 | 24 |
26 | 339000000 | 15.1 | 38 | QAM 256 | 26 |
27 | 347000000 | 15.1 | 39 | QAM 256 | 27 |
28 | 355000000 | 15 | 39 | QAM 256 | 28 |
29 | 363000000 | 15 | 39 | QAM 256 | 29 |
30 | 371000000 | 15.2 | 39 | QAM 256 | 30 |
31 | 379000000 | 15.2 | 39 | QAM 256 | 31 |
1 | Locked | 39 | 87887 | 28837 |
2 | Locked | 39 | 402 | 2595 |
3 | Locked | 39 | 6219 | 109041 |
4 | Locked | 39 | 3229 | 97420 |
5 | Locked | 39 | 3081 | 105644 |
6 | Locked | 39 | 2588 | 100988 |
7 | Locked | 39 | 2200 | 14664 |
8 | Locked | 39 | 2585 | 107040 |
9 | Locked | 39 | 2295 | 106766 |
10 | Locked | 38 | 1856 | 104987 |
11 | Locked | 38 | 5616 | 119924 |
12 | Locked | 38 | 1217 | 107494 |
13 | Locked | 39 | 1352 | 43878 |
14 | Locked | 38 | 3617 | 50775 |
15 | Locked | 38 | 6915 | 56458 |
16 | Locked | 39 | 7011 | 62099 |
17 | Locked | 38 | 3610 | 55338 |
18 | Locked | 38 | 2335 | 114748 |
19 | Locked | 38 | 2174 | 117114 |
20 | Locked | 39 | 9727 | 65547 |
21 | Locked | 39 | 6015 | 59118 |
22 | Locked | 39 | 30750 | 88863 |
23 | Locked | 39 | 3737 | 59613 |
24 | Locked | 39 | 25588 | 80547 |
25 | Locked | 39 | 37319 | 103784 |
26 | Locked | 38 | 3693719 | 2204861 |
27 | Locked | 39 | 387466 | 492439 |
28 | Locked | 39 | 96175 | 228044 |
29 | Locked | 39 | 104599 | 234111 |
30 | Locked | 39 | 466847 | 405216 |
31 | Locked | 39 | 513216 | 379985 |
3.1 Downstream channels
159 | 94 | 4K | 1840 | QAM 4096 | 1108 |
159 | Locked | 35 | 9.7 | 681730079 | 907495 |
on 09-11-2023 17:40
Upstream:
3.0 Upstream channels
0 | 49600000 | 36.3 | 5120 | QAM 64 | 1 |
1 | 43100000 | 37.3 | 5120 | QAM 64 | 2 |
2 | 36600000 | 38 | 5120 | QAM 64 | 3 |
3 | 30100000 | 38.3 | 5120 | QAM 64 | 4 |
4 | 23600000 | 38.3 | 5120 | QAM 64 | 5 |
0 | ATDMA | 0 | 74 | 15 | 1 |
1 | ATDMA | 0 | 74 | 63 | 2 |
2 | ATDMA | 0 | 74 | 97 | 4 |
3 | ATDMA | 0 | 74 | 66 | 3 |
4 | ATDMA | 0 | 74 | 48 | 0 |
3.1 Upstream channels
6 | 10 | 29.7 | 2K | QAM 256 |
6 | OFDMA | 200 | 74000000 | 45 | 0 |
on 09-11-2023 17:41
Network log:
09-11-2023 17:37:12 | notice | GUI Login Status - Login Success from LAN interface |
09-11-2023 17:27:39 | critical | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
09-11-2023 17:24:23 | critical | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
09-11-2023 17:20:00 | notice | US profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
09-11-2023 17:20:00 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
09-11-2023 17:19:36 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
09-11-2023 17:19:36 | notice | US profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
09-11-2023 17:18:31 | notice | US profile assignment change. US Chan ID: 6; Previous Profile: 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
09-11-2023 17:18:31 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
09-11-2023 16:48:05 | notice | US profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
09-11-2023 16:48:05 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
09-11-2023 16:47:41 | notice | US profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
09-11-2023 16:47:41 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
09-11-2023 16:46:56 | notice | US profile assignment change. US Chan ID: 6; Previous Profile: 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
09-11-2023 16:46:56 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
09-11-2023 16:16:20 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
09-11-2023 16:16:20 | notice | US profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
09-11-2023 16:15:55 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
09-11-2023 16:15:55 | notice | US profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
09-11-2023 16:15:31 | notice | US profile assignment change. US Chan ID: 6; Previous Profile: 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
09-11-2023 16:15:31 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
09-11-2023 15:43:54 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
09-11-2023 15:42:54 | error | DBC-ACK not received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
09-11-2023 15:42:51 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
09-11-2023 15:42:51 | notice | US profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
09-11-2023 15:42:27 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
09-11-2023 15:42:27 | notice | US profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
09-11-2023 15:42:03 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
09-11-2023 15:42:03 | notice | US profile assignment change. US Chan ID: 6; Previous Profile: 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
09-11-2023 15:35:09 | critical | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
09-11-2023 15:31:14 | critical | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
09-11-2023 15:27:34 | notice | CM-STATUS message sent. Event Type Code: 23; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
09-11-2023 15:24:55 | critical | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
10-11-2023 17:20 - edited 10-11-2023 17:23
Thats a dreadful connection 😡
Down power levels are all way too high and there are unacceptable numbers of PostRS errors and Up T errors - if there is no known issue it will need a Tech visit
I will alert VM to take a look and contact you here
on 10-11-2023 17:25
Thankyou!! Really appreciate the assistance and look forward to speaking with VM
