MC_64
Message 1 of 7
Connection
I am working from home but about 5 times a day my work laptop loses wifi connection and I have to disconnect and reconnect. I have rebooted etc but still having same issue. Also if watching something on tablet that also cuts out regularly. Any suggestions - not too technical please
-tony-
  • 16K
  • 1.26K
  • 3.77K
Message 2 of 7
Re: Connection
do you have any wired connections if so do they cut out - if you dont have wired connections what do the lights on the hub do when you lose connection
log into hub3 - 192.168.0.1 [or 192.168.100.1 if in modem mode] - DON'T SIGN IN, click - click router status [centre of screen] - and post the downstream and upstream figures - to see those press on the grey buttons/boxes labelled - upstream - downstream
if its an earlier hub button is top right
____________________
Tony
MC_64
Message 3 of 7
Re: Connection
Which figures do you need?
-tony-
  • 16K
  • 1.26K
  • 3.77K
Message 4 of 7
Re: Connection
the ones i asked for above - cut and paste them also details on how you are connected
Tony
MC_64
Message 5 of 7
Re: Connection
MC_64
Message 6 of 7
Re: Connection
Thanks Tony.  I appreciate your help.  I'm not good at this sort of thing - just need laptop and wi-fi that works.
What do you mean by how am I connected?
-tony-
  • 16K
  • 1.26K
  • 3.77K
Message 7 of 7
Re: Connection
are you connected by wifi or a lan cable - guess the answer is wifi from your last comment
your levels are not good - not a disaster but they need looking at - downstream is too low -6 in minimum and you have some below that - upstream is in spec [just] but at 51 and problems could do with being lower
so do you have an attenuator on the input - a small barrel shaped connector between the coax in and the hub - if you have remove it - post new figures back and see it the connection is any more stable
if not you need a tech to do some adjustment - wait here or ring it in - if you ring it in they are likely to send you a new hub - will not help [usually] but they think it will because the script says so - have non of it push them to book a tech
Tony
