Faye05
Connection to telly and phones keeps disconnecting
Our connection to the telly and our phones regularly disconnects. It seems to help if we switch off the telly and our virgin box then wait and turn it back on but it’s very frustrating.
any help would be greatly appreciated.
  • 35.1K
  • 3.41K
  • 6.68K
Re: Connection to telly and phones keeps disconnecting
What model of VM Hub do you have - printed on its sticker? Also what TV box is it - TiVo, Vr6,360?
How is your TV connecting to the Hub (internet) - is that on wifi or via an ethernet cable?
Also do you have any connection issues to the internet through your VM broadband on cpmputers/laptops/consoles/phones/etc,?
Faye05
Hi there,
This is what we have. Hub3.0 VMSG505.
Our telly connects via Wi-Fi. We have issues with our phones and laptop yes.
Many thanks
  • 35.1K
  • 3.41K
  • 6.68K
OK - so you do not have a VM TV box and subscription.
Try conncting the TV on an ethernet cable temporarily to see if that solves the issue. If it does,... then make that connection "permanent" - or improve the wifi signal at the location of the TV.
With a Hub3 you can try this first, hope it makes sense ...
___________________________
If you haven't done this already - try it first - it helps sort some Hub3/4/5 wifi issues for some devices.
Go into the Hub’s settings. Type in  http://192.168.0.1  into your web browser’s url box and login with settings password on the Hub's base sticker (or your own if you changed it). Then in Advanced>wireless signal >smart wifi - tick the disable “channel optimisation” box or the“Smart Wifi” box and save settings.  May be different pathways and wording on the 3 Hub types
Then, go to advanced>wireless signal>security, rename the 2.4 & 5 GHz network ssid's.  Just type over to change 'em to whatever you like and something that will differentiate them (e.g - Faye_2 & Faye_5) Try to avoid spaces and periods in the SSID names as they can cause issues with certain devices. Use the same password for simplicity,  Then, apply settings and restart the Hub.  Your 2 wifi networks will now be clearly separated - and you can then select the network you want each device to connect to… individually from the "available networks" list on each of your devices.
Note all your wifi devices will need re-connecting to the new SSID's and passwords.
All things being equal, 5 GHz is always better/faster and subject to less congestion/interference (and is better for iDevice speeds than the 2.4 one - although the 2.4 one has the better "range" and will be needed when the 5 GHz drops out of range and some older/cheaper/dumber or “specialised” devices can only use this one.
You should also use a wifi analyser App (or Airport Utility on iOS) to check which 2.4 channels are being heavily used around you and move yours to one of numbers 1,6,11 that is least so, but it wont help if there is other interference.
See if these changes help - you will lose any “seamless roaming” benefits but it may not matter and you can always change the settings back by doing a " pinhole factory reset " if you prefer the way it was - or it doesn’t help.
If that doesn't work post back for other options
