blingbling
Connection to hub 3 issue
I set up my hub 3 to connect go app and now its not connecting and not allowing me to reconnect at all. Anybody else had this issue or can help?
lotharmat
  • 2.54K
  • 189
  • 462
Trouble shooter
Re: Connection to hub 3 issue
Do you use Android 11? There is an issue with that and the connect app
blingbling
Yes I do
lotharmat
  • 2.54K
  • 189
  • 462
Trouble shooter
Alas you will need to wait for VM to fix the app - I believe it has been punted to the devs!
blingbling
I will be patient 😌
  • 16.28K
  • 711
  • 1.6K
@blingbling wrote:
I will be patient 😌
years patient....
