It seems there may have been an update that caused it.
You may be as well refining your Wi-Fi management, it will certainly help keeping track of your Wi-Fi frequencies.
Best done with a cable connected device.
Instructions for Hub 3, Hub 4 is similar.
Log in to the Hub.
Advanced Settings > Wireless > Security > Add 2* to the 2.4GHz Channel name [SSID] > Add 5* to the 5 GHz Channel name [SSID] > Click ‘Apply Changes’
* You can change the SSID to whatever you want but I advise the name starts or ends with the frequency.
Log out of the Hub then reboot using this method ...
Switch the Hub off using the small switch on the rear of the Hub next to the power cord and pull the PSU plug from the wall socket.
While the Hub is powered off go around all the accessible co-ax connectors inside and outside to ensure that they are finger tight.
Give it a good 5 minutes put the plug back in and switch the Hub back on.
Allow the Hub a few minutes to fully restart then try your Wi-Fi again.
You will need to reconnect all you Wi-Fi devices some will want to connect to 5Ghz and some to 2.4GHz and some will connect to either.
When you connect the devices do it at the furthest point from the Hub that the device will be used.
