  • 8
Connection/ speed
What is happening with internet speed???
I am connectedcti wi fimusing ethernet but getting no connectivity through smart tv ( so no netflix or amazon prime, but if I go to HDMI 2 where firestick is, I can connect)??
Run speed test but getting less than 10mb.
Tried to log on to router but have forgotten password and no option to reset???
Tags (2)
  • 12.3K
  • 952
  • 1.58K
Re: Connection/ speed
Which Hub have you got ?
What is your Contracted speed ?
What speed do you get at >> speedtest.net << with a direct connection using a Cat 5E/6 cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
Mike Robinson
  • 12.3K
  • 952
  • 1.58K
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting your district. Be aware that it isn't a manned line.
Go round all the accessible internal and external co-ax connections and ensure that they are finger tight.
If everything above is OK we need do some more troubleshooting; to start with …
Then
Can you please
Mike Robinson
  • 25.23K
  • 1.45K
  • 3.21K
Running a speedtest from what device and over wired or wireless?
