  • 6
Message 1 of 12
Connection problem click me button
My hub 3.0 is showing a pop up when I try to connect to the Internet.
The pop up contains a large red 'Click me' button and the following text:
"Connection problem. We are having trouble connecting you to the internet. If you click the button above, we will try to fix your problems."
I've done 2 factory resets but the pop up still appears.
What should I do?
  • 6
Message 2 of 12
Re: Connection problem click me button
Screenshot of the pop up 
  • 6.62K
  • 494
  • 870
Legend
Message 3 of 12
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting the area. Be aware that it isn't a manned line.
Mike Robinson
Aircraft Engineer & Computer Based Training and Learning Designer for many of the world's Military Arms.
  • 6
Message 4 of 12
Yep it said service is normal.
Also when I clicked the button, this came up:
1. gateway IPv4 is not valid.
2. Your broadband connection is down.
  • 6.62K
  • 494
  • 870
Legend
Message 5 of 12
Try this ...
Switch the Hub off for 5 minutes using the small switch on the rear of the Hub next to the power cord.
Allow the Hub a few minutes to fully restart then try your connection again.
Mike Robinson
  • 6
Message 6 of 12
Still same..
Could I just book an engineer for this please?
  • 6.62K
  • 494
  • 870
Legend
Message 7 of 12
You can contact VM to report the problem using ...
Text service on 07533051809
150 from Virgin landline.
0345 454 1111 from any other UK  phone.
The best time to call is weekdays 08:00 to get a UK agent, anything after 10:00 you must realise that you are quite likely to get through to an offshore agent that doesn't speak English as a first language.
Or you can wait on here for one of the VM Staff to pick up the thread but this may take a few days.
Mike Robinson
  • 6
Message 8 of 12
Thank you Mike,
Is there anything else I can try while waiting for a staff?
  • 6.62K
  • 494
  • 870
Legend
Message 9 of 12
You can try a pin hole / factory reset.
Do it exactly as this method ...
DO NOT DO THIS if the password on the base of the Hub is not legible or missing.
Instructions for Hub 3
Disconnect all unneeded ethernet cables from the rear of the Hub.
With the Hub Powered on use a paperclip or similar and do a pinhole reset.
DO NOT reboot the hub but allow it 5 to 10 minutes for it to boot itself up.
Once a steady white and no other lights are illuminated check your system again.
Mike Robinson
  • 6
Message 10 of 12
Hi Mike
I've tried but still not working.
