  • 26
Message 1 of 21
Connection losses regularly
Hi guys
For days i've been wrestling with my router wondering what is causing so many connection losses wired and wifi, ive read the logs that don't read well the most recent one was last night when i was asleep and not using any devices
I'm not a network tech guy i know some stuff but not enough to talk about it but i'm pretty sure this is wrong on my upstream right? and if so is that what is causing so many problems? and how to fix it please?
  • 2.21K
  • 163
  • 290
Dialled in
Message 2 of 21
Re: Connection losses regularly
Could you post the raw data from the tabs, rather than screenshots, as we can't see them until they are approved, which can take time.
  • 26
Message 3 of 21
can you advise on how i do that please?
  • 2.21K
  • 163
  • 290
Dialled in
Message 4 of 21
Have you already accessed the HUB?
You can manually select all the data in the tabs, like you would in MS Word, copy it, then paste into a new post.
An error may occur, however you can click post a second time.
The data may also need to be split into multiple posts.
  • 26
Message 5 of 21
for now i will just write out the data
upstream bonded channel
CHANNEL 1  Frequenzy 39400068 power 5.5 symbol rate 5120 mod 64 qam channel id 2
  • 26
Message 6 of 21
1394000685.5512064 qam2
  • 26
Message 7 of 21
01/08/2020 12:03:27noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/08/2020 12:03:22Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/08/2020 11:44:10noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/08/2020 02:19:18criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/08/2020 02:19:18criticalUnicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/08/2020 02:18:58criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/08/2020 02:18:58criticalUnicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/08/2020 02:18:38criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/08/2020 02:18:38criticalUnicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/08/2020 02:18:18criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/08/2020 02:18:18criticalUnicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:33criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/07/2020 21:36:4noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/07/2020 20:13:16Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/07/2020 20:13:12criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/07/2020 20:13:12Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/07/2020 19:55:44criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/07/2020 19:55:44criticalUnicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
  • 3.5K
  • 567
  • 1.38K
Message 8 of 21
I didn't think there was anything particularly difficult in selecting and copying text, and then pasting it into a forum reply as text?  Am I missing something here?
If you're going to type out each individual line then this is going to take a very long time indeed.
Ahh, you've done it.  Well done.
From what you've posted it appears that you've only got one upstream channel (should be four) and that's operating well out of tolerance for power level.
  • 2.21K
  • 163
  • 290
Dialled in
Message 9 of 21
Yep, you need an engineer visit.
  • 26
Message 10 of 21
thanks guys, yeah sorry about the writing part i had a blank moment lol
will book an engineer,
Thanks for help
