acarpe81
Message 1 of 9
Connection keeps dropping
Unfortunately multiple times during the day the internet connection to my router drops (running in modem mode with a Netgear Nighthawk router).
Here's my network log:
07/07/2021 07:55:24noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt060-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/07/2021 07:55:24ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/07/2021 05:37:42criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/07/2021 12:31:0Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/07/2021 12:31:0criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/07/2021 01:26:28noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt060-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/07/2021 01:26:28ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/07/2021 10:54:17Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/07/2021 10:54:17criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/06/2021 21:11:59criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/06/2021 12:40:9Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/06/2021 19:51:28noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt060-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/06/2021 19:51:28ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/06/2021 12:14:46criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/06/2021 07:51:28noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt060-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/06/2021 07:51:28ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/06/2021 18:56:27Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/06/2021 18:56:27criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/06/2021 12:47:39Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/06/2021 12:47:39criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
acarpe81
Message 2 of 9
Re: Connection keeps dropping
1419000000-440256 qam32
2203000000-3.940256 qam9
3211000000-3.738256 qam10
4219000000-3.938256 qam11
5227000000-3.740256 qam12
6235000000-3.938256 qam13
7243000000-440256 qam14
8251000000-3.540256 qam15
9259000000-440256 qam16
10267000000-440256 qam17
11275000000-4.440256 qam18
12283000000-4.538256 qam19
13291000000-3.738256 qam20
14299000000-3.540256 qam21
15307000000-3.540256 qam22
16315000000-3.440256 qam23
17323000000-3.740256 qam24
18363000000-3.740256 qam25
19371000000-3.740256 qam26
20379000000-3.540256 qam27
21387000000-4.240256 qam28
22395000000-440256 qam29
23403000000-4.240256 qam30
24411000000-4.438256 qam31
1Locked40.924931966
2Locked40.325932620
3Locked38.924441930
4Locked38.920691877
5Locked40.922431855
6Locked38.924792158
7Locked40.324342332
8Locked40.323321955
9Locked40.319211691
10Locked40.319851733
11Locked40.323142137
12Locked38.927972329
13Locked38.925612170
14Locked40.322291600
15Locked40.318721478
16Locked40.919291714
17Locked40.322161746
18Locked40.321982229
19Locked40.323162141
20Locked40.322861616
21Locked40.319781195
22Locked40.915961007
23Locked40.318621211
24Locked38.923651656
14620001450.8512064 qam11
22580000047.8512064 qam14
33259998647.8512064 qam13
43940002448.3512064 qam12
1ATDMA0010
3ATDMA0000
4ATDMA0000
lotharmat
  • 2.54K
  • 189
  • 462
Trouble shooter
Message 3 of 9
Power levels are not out of spec.. Upstream maybe a little high downstream maybe a little low.
I can see the odd loss of sync and T3 timeout!
VM will want to test it out - to do this, you'll need the hub in router mode.
Gareth_L
  • 6.89K
  • 423
  • 778
Message 4 of 9
Hello acarpe81
If you can please put the Hub into router mode and let us know
That way we can check a few things from here
Gareth_L
acarpe81
Message 5 of 9
Thanks Gareth. I've just switched it back over to router mode. Kind regards
Gareth_L
  • 6.89K
  • 423
  • 778
Message 6 of 9
Thanks acarpe81
Will have a look right away
Gareth_L
Gareth_L
  • 6.89K
  • 423
  • 778
Message 7 of 9
Hi acarpe81
I have had a look and the Downstream has flagged up an one upstream level is out of range
It is going to need an engineer to come out
I will need to send you a private message to pass security to arrange this
If you can check the purple envelope top right of your screen that would be great
Gareth_L
Gareth_L
  • 6.89K
  • 423
  • 778
Message 8 of 9
Are we okay calling on the number ending 0965
Gareth_L
acarpe81
Message 9 of 9
No, that number not used. Details sent via PM. Many thanks
