Connection keeps dropping (DNS Issue) after area outage
mythil
After the area outage on the 20th in the PO9 area I've had a constant "brown out" of my broadband. It appears to be a DNS issue or something similar because I'm not getting "disconnected" but services will just stop for 10 seconds then start again. I've got a wired connection to my PC, wireless on other devices, made sure all connections are tight etc but nothing seems to fix it.
1 ACCEPTED SOLUTION
Accepted Solutions
Seeing only 60Mb/s  could be signs of a failing network cable that has de-rated from 1000 to 100 & is still causing errors.
First call 0800 561 0061 - use the automated service to see if there is a local service issue.
Speed test the service to a Router mode Hub(3/4/5) + your device with the link below.
The speed at the Hub should reflect your subscription. ( M500 )
The speed any connected / WiFi device draws is limited by the connection quality and its technical abilities.
3 REPLIES 3
mythil
I am also now only getting roughly 60mbs when I'm paying for over 500mbs
Hi mythil,
Thank you for your post. I'm very sorry to hear about the issue with your Broadband service.
I have taken a look on our side and it looks like you were able to speak with the team regarding this.
Please let us know how if you need any further assistance.
^Martin
