Hi @Roberto1212
I am sorry for any connection issues. Please could you confirm the answer to Tudor's question? (Thank you Tudor).
If it's both wired and wireless, please can you post your Hub status and logs? How to do this;
• Copy/paste the data from each of the tabs as text into a 'REPLY' as opposed to 'QUICK REPLY'. Please do not include your MAC address.
Also, set up a 'Broadband Quality Monitor'. This will monitor the state of your connection and record any network dropouts etc - You can do this at https://www.thinkbroadband.com/broadband/monitoring/quality
Give it a while to gather data and then click 'Share Live graph' and paste the 'Direct Link' into the forum 🙂
If it's just a wireless issue and you have a Hub 3 or over, please use the Connect App 👉 https://www.virginmedia.com/broadband/connect-app when downloaded, you'll be able to do a wireless scan in the property. This will check and identify any coverage blackspots. It'll optimise them where possible and if a Pod is needed, you'll be prompted to order.
Kind regards,
