Wood66
Message 1 of 11
Connection issue VPN/Cisco
noticed all the posts regarding the poor connections whilst working from home using VPN/Cisco
im having horrendous issues & ive seen that you can turn off your firewall - can anyone give me an idiots guide of how to do this? ive been on my virgin media & can see my Hub but no option to turn off anything just reboot - im no IT specialist so please make it simple!
spgray
  • 2.39K
  • 139
  • 339
Problem sorter
Message 2 of 11
Re: Connection issue VPN/Cisco
by firewall they mean turn off "web safe"
https://www.virginmedia.com/help/how-to-use-websafe
My Broadband Ping - spgray
Christy_D
  • 1.28K
  • 186
  • 210
Message 3 of 11
If you log into your 192.168.0.1 page and enter your hub settings password on the bottom of your router. If you go to the Dashboard, then into the Advanced tab down the side, then into Security, then into the Firewall tab. You can disable and apply the settings here.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 4 of 11
Type 192.168.0.1 (192.168.100.1 if in Modem Mode) into your browser URL bar and press enter.
Enter your password and click Next
Advanced Settings > Security > Firewall > Firewall Protection > Uncheck Enabled > Apply Changes.
DJ_Shadow1966
  • 6.84K
  • 1.31K
  • 1.88K
Message 5 of 11
Hello
You will need  to login into the hub by going too http://192.168.0.1 using the login details from the base of the hub will be marked as settings password.
Once logged in you will see a screen like this
Once on this screen selected Advanced and the Firewall screen will look like
Unick Firewall and then click Apply Changes.
Regards Mike
spgray
  • 2.39K
  • 139
  • 339
Problem sorter
Message 6 of 11
i'm pretty sure no-one is suggesting complete disabling the hubs firewall - that would be insanity.
turning off websafe would be the first thing to try, and if no luck there opening the specific ports required for the VPN.
completely disabling the firewall is a bad move.
spgray
  • 2.39K
  • 139
  • 339
Problem sorter
Message 7 of 11
that's IPv6 firewall though, and virgin uk doesn't use IPv6 ?
nuraika
  • 21
Message 8 of 11
Looks like this has not been resolved. as of today i am having issues with Virgin while using a Cisco VPN to connect to my work servers. I'm getting similar drop-out probs to what I had last year withen using a different VPN at a previous employer.
Id be interested in hearing if you got a resolution to this
lotharmat
  • 770
  • 53
  • 108
Well-informed
Message 9 of 11
I've replied on the thread you've started - hopefully others will also post.
I'm using the CISCO anytime VPN for work and have been for over a year now with zero issues - only disconnect is after 12 hours it auto disconnects but that is set by our company
Martin_N
  • 5.27K
  • 222
  • 301
Message 10 of 11
Hi nuraika,
Thank you for your post and welcome to the community.
I'm very sorry to hear about the issue you're having.
Just to confirm have you been able to try what has been suggested by other users?
^Martin
