Message 1 of 7
Connection in a room causing me problems
Been a virgin media account holder since 1st May moving from talktalk, However am finding that the internet service is not up scratch on what you offered me, I can connect in some rooms brilliantly and other not however when I do a blackspot check its sayings its great and no need for a booster however this is not the case for example: In the loft yes furthest place away from the router however my laptop, 2 phones and sonos and work laptop can connect, However my Ps4 connect why, am only getting at most 2mpbs?  Do I need a booster? If I do need a booster why don't you have them in stock?
Can you please advise.
  • 11.37K
  • 787
  • 1.6K
Message 2 of 7
Re: Connection in a room causing me problems
It's normal the further away you are from the hub the slower the speed and weaker the signal.  That's not a fault that's just physics.
You can buy your own WiFi extenders or you can call virgin to get there own ones posted out
I work for Virgin Media and my posts are my own opinions
Message 3 of 7
Thanks JB but it was fine when I was with Talktalk, So this is the confusing, With Vm saying the room is fine when I ve scanned it
  • 11.37K
  • 787
  • 1.6K
Message 4 of 7
The scanning app isn't very clever.  It's probably detected you have a strong enough 2.4ghz (slow signal) but you may have a non existant 5ghz signal (fast).
The talk talk router may have a better range if they were in the exact same place as I imagine their routers are built for range rather than speed in mind
Message 5 of 7
So you suggest I wait till my booster comes and see what that does?
  • 20.96K
  • 1.13K
  • 2.7K
Message 6 of 7
Get a router or mesh system from Amazon or run some wired AP’s
  • 11.37K
  • 787
  • 1.6K
Message 7 of 7
If you have a booster it will help as your PlayStation can be hard wired into it
