ryanbate
Connection failing on heavy uploads
Looking for advice from any community members that can advise on levels and such like and (if available, eventually) any VM staff who can do the same.
We have M200 broadband having been successively upgraded over the years in speed. Modem is a Superhub 2ac which is used in modem mode with a separate router.
In performing large cloud backups I am noticing that after a few minutes of sustained upload (effectively maxing out the speed allowed) the connection completely fails. When it does this, the only remedy is to restart the Superhub and then all is well assuming that the upload does not resume - if it does, it fails again within around 20-30 minutes.
I have looked through the operation log on the SH and cannot see only see messages that I believe relate to it booting up and establishing connection again.
This graph is taken from my router and shows throughput as recorded by it - green for download and blue for upload. You can see that the spikes in upload correspond with when the traffic drops to zero.
Data from the SH status pages and logs  are here:
Spoiler
Information
Cable Modem EuroDOCSIS 3.0 Compliant
Serial Number XXXXXXXXXXXX
Boot Code Version PSPU-Boot 1.0.20.1391
Software Version V2.01.15
Hardware Version 1.03
CA Key Installed
Cable Modem Status
Item Status Comments
Acquired Downstream Channel (Hz) 283000000 Locked
Ranged Upstream Channel (Hz) 46200000 Success
Provisioning State OK Operational
Downstream
DS-1 DS-2 DS-3 DS-4 DS-5 DS-6 DS-7 DS-8
Frequency (Hz) 283000000 267000000 275000000 291000000 299000000 307000000 315000000 323000000
Lock Status(QAM Lock/FEC Sync/MPEG Lock) Locked Locked Locked Locked Locked Locked Locked Locked
Channel ID 19 17 18 20 21 22 23 24
Modulation 256QAM 256QAM 256QAM 256QAM 256QAM 256QAM 256QAM 256QAM
Symbol Rate (Msym/sec) 6.952000 6.952000 6.952000 6.952000 6.952000 6.952000 6.952000 6.952000
Interleave Depth I=12
J=17 I=12
J=17 I=12
J=17 I=12
J=17 I=12
J=17 I=12
J=17 I=12
J=17 I=12
J=17
Power Level (dBmV) 7.13 6.58 6.85 7.50 7.78 7.87 8.01 8.01
RxMER (dB) 38.61 38.26 38.26 38.61 38.98 38.26 37.94 39.40
Pre RS Errors 277 292 288 929 329 919 322 950
Post RS Errors 275 290 288 929 329 919 322 950
Upstream
US-1 US-2 US-3 US-4
Channel Type 2.0 2.0 2.0 2.0
Channel ID 1 4 3 2
Frequency (Hz) 46200000 25800000 32600000 39400000
Ranging Status Success Success Success Success
Modulation 64QAM 64QAM 64QAM 64QAM
Symbol Rate (Sym/sec) 5120000 5120000 5120000 5120000
Mini-Slot Size 2 2 2 2
Power Level (dBmV) 42.50 42.50 42.50 42.50
T1 Timeouts 0 0 0 0
T2 Timeouts 0 0 0 0
T3 Timeouts 0 0 0 0
T4 Timeouts 0 0 0 0
Upstream Burst
Req
(1) Init Maint
(3) Per Maint
(4) Adv Short
(9) Adv Long
(10) Adv UGS
(11)
Modulation Type 16QAM QPSK 16QAM 64QAM 64QAM 16QAM
Differential Encoding OFF OFF OFF OFF OFF OFF
Preamble Length 36 384 384 64 64 64
Preamble Value Offset 396 6 6 396 396 396
FEC Error Correction (T) 0 5 5 7 14 5
FEC Codeword Information Bytes (K) 16 34 34 88 220 86
Maximum Burst Size 0 0 0 3 0 55
Guard Time Size 22 48 48 22 22 22
Last Codeword Length Fixed Fixed Fixed Shortened Shortened Shortened
Scrambler On/Off ON ON ON ON ON ON
General Configuration
Network Access Allowed
Maximum Number of CPEs 1
Baseline Privacy Enabled
DOCSIS Mode EuroDOCSIS 3.0
Config File
SFID 210
Max Traffic Rate 230000061 bps
Max Traffic Burst 42600 bytes
Min Traffic Rate 0 bps
Primary Upstream Service Flow
SFID 209
Max Traffic Rate 22000061 bps
Max Concatenated Burst 42600 bytes
Scheduling Type Best Effort
First Time Last Time Priority Error Number Description
08/10/2019 13:29:12 GMT 08/10/2019 13:29:12 GMT Error (4) 68000407 TOD established
Time Not Established Time Not Established Notice (6) 84000510 Downstream Locked Successfully
08/10/2019 07:58:05 GMT 08/10/2019 07:58:05 GMT Error (4) 68000407 TOD established
08/10/2019 07:57:47 GMT 08/10/2019 07:57:47 GMT Notice (6) 84000510 Downstream Locked Successfully
08/10/2019 07:57:42 GMT 08/10/2019 07:57:42 GMT Critical (3) 82000400 Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out
08/10/2019 07:57:22 GMT 08/10/2019 07:57:22 GMT Critical (3) 82000400 Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out
08/10/2019 07:57:02 GMT 08/10/2019 07:57:02 GMT Critical (3) 82000400 Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out
08/10/2019 07:56:42 GMT 08/10/2019 07:56:42 GMT Critical (3) 82000400 Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out
07/10/2019 19:55:35 GMT 07/10/2019 19:55:35 GMT Error (4) 68000407 TOD established
07/10/2019 18:48:10 GMT 07/10/2019 18:48:10 GMT Error (4) 68000407 TOD established
07/10/2019 18:47:55 GMT 07/10/2019 18:47:55 GMT Notice (6) 84000510 Downstream Locked Successfully
07/10/2019 18:47:49 GMT 07/10/2019 18:47:49 GMT Critical (3) 82000400 Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out
07/10/2019 18:47:29 GMT 07/10/2019 18:47:29 GMT Critical (3) 82000400 Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out
07/10/2019 18:47:09 GMT 07/10/2019 18:47:09 GMT Critical (3) 82000400 Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out
07/10/2019 18:46:49 GMT 07/10/2019 18:46:49 GMT Critical (3) 82000400 Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out
07/10/2019 18:45:59 GMT 07/10/2019 18:45:59 GMT Warning (5) 84020200 Lost MDD Timeout
I can see that my router is not breaking a sweat from the traffic (it's a Mikrotik RB3011UIAS RM - massive overkill) and that the connection comes back without resetting that or having to interact with it in any way.
I can see the upload speed limit is currently set to ~22Mbps which was completely unbeknown to me so perhaps this is why this issue is only now starting to become apparent if there are wonky levels. Or potentially that given the SH2ac is an older piece of kit it may not be up to the job for this kind of upload speed?
Any thoughts or insight would be appreciated.
  • 6.59K
  • 511
  • 1.1K
Legend
Re: Connection failing on heavy uploads
Stats look ok, but T4 timeouts in the log are bad. Possibly a noise ingress problem in your local area. Phone customer services and see if there is a reported problem.
  • 1.24K
  • 60
  • 96
Hi ryanbate,
Sorry to hear that your broadband connection is failing on heavy uploads.
Just looking the details already provided, I cannot see any errors on our end.
Is the connection failing in general or just when your conducting heavy uploads?
Please give us more information so we can help.
Regards,
Lisa
  • 4.97K
  • 348
  • 845
Roger_Gooner
Superstar
In view of the wild swings in speeds I'm inclined to think that this is a network issue, quite possibly within the hub site. If so a VM technician won't be able to fix it.
Hub 3.0, TP-Link Archer C8, TP-Link TL-SG1008D 8-port gigabit switch, V6
ryanbate
The wild fluctuations in speed (or rather current data throughput) are when the cloud backup process started and when the broadband "fell over". I was able to prevent it doing so by limiting the cloud backup to self-limit to 8Mbps, since which the connection has remained stable.
I am not at the site at the moment and given that a manual reset is required when it does fall over I am hesitant to do any further testing that might jeopardise the connection but will do so when I am next there.
I assume there are no issues on the levels, etc?
If not then I would question whether or not the SH2ac is up to the job of delivering 22Mbps sustained upload over a long period.
When the connection does fail, it's notable that the online troubleshooter diagnostics page shows as if the device is not connected at all.
Ryan
  • 3.38K
  • 158
  • 267
Hi ryanbate,
Thanks for posting and welcome to the community. I've checked the account and area and no issues are showing. You have an older hub, the 2ac, which we can swap for you to a hub 3 free of charge. If you wish for me to do so, please let me know and I'll get the ball rolling on this.
Kind regards,
John_GS
