Message 1 of 5
Connection Issue
I've been having connection issues for about a week now where the hub seems fine and have a white light though there is no internet. I've done all the checks and tried to call and did all the things that were suggested online but have found no solution. I've attached information from my router and hope someone here can help me. Thanks.
Channel
Frequency (Hz)
Power (dBmV)
SNR (dB)
Modulation
Channel ID
1
187000000
9.5
40
256 qam
7
2
139000000
10.9
38
256 qam
1
3
147000000
10.5
38
256 qam
2
4
155000000
10.1
40
256 qam
3
5
163000000
10
40
256 qam
4
6
171000000
10
40
256 qam
5
7
179000000
9.5
40
256 qam
6
8
195000000
8.9
40
256 qam
8
9
203000000
7.5
38
256 qam
9
10
211000000
7.1
38
256 qam
10
11
219000000
6.9
38
256 qam
11
12
227000000
6.5
38
256 qam
12
13
235000000
6.5
38
256 qam
13
14
243000000
6.8
40
256 qam
14
15
251000000
6.9
38
256 qam
15
16
259000000
6.8
38
256 qam
16
17
267000000
6.4
38
256 qam
17
18
275000000
6.4
40
256 qam
18
19
283000000
6.5
40
256 qam
19
20
291000000
6.5
38
256 qam
20
21
299000000
6.6
38
256 qam
21
22
307000000
7.3
40
256 qam
22
23
315000000
7
38
256 qam
23
24
323000000
6.9
38
256 qam
24
Channel
Locked Status
RxMER (dB)
Pre RS Errors
Post RS Errors
1
Locked
40.3
17
0
2
Locked
38.9
5
0
3
Locked
38.9
5
0
4
Locked
40.3
21
0
5
Locked
40.3
5
0
6
Locked
40.3
6
0
7
Locked
40.3
0
0
8
Locked
40.3
5
0
9
Locked
38.9
0
0
10
Locked
38.9
12
0
11
Locked
38.9
5
0
12
Locked
38.9
5
0
13
Locked
38.9
6
0
14
Locked
40.3
6
0
15
Locked
38.9
6
0
16
Locked
38.9
6
0
17
Locked
38.9
5
0
18
Locked
40.3
5
0
19
Locked
40.3
5
0
20
Locked
38.9
6
0
21
Locked
38.9
7
0
22
Locked
40.9
4
0
23
Locked
38.9
5
0
24
Locked
38.9
6
0
Channel
Frequency (Hz)
Power (dBmV)
Symbol Rate (ksps)
Modulation
Channel ID
1
53700009
3.65
5120
64 qam
10
2
39400004
3.65
5120
64 qam
12
3
46199983
3.65
5120
64 qam
11
4
60299986
3.65
5120
64 qam
9
Channel
Channel Type
T1 Timeouts
T2 Timeouts
T3 Timeouts
T4 Timeouts
1
ATDMA
0
0
0
0
2
ATDMA
0
0
0
0
3
ATDMA
0
0
0
0
4
ATDMA
0
0
0
0
Message 2 of 5
Re: Connection Issue
Time
Priority
Description
26/08/2020 20:57:6
notice
LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/08/2020 20:56:57
Warning!
LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/08/2020 20:25:7
notice
26/08/2020 06:20:23
critical
25/08/2020 01:36:24
notice
DHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt057+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/08/2020 01:36:24
Error
DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/08/2020 01:07:50
critical
25/08/2020 00:58:32
critical
DHCP FAILED - Discover sent, no offer received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/08/2020 00:56:44
critical
25/08/2020 00:56:2
critical
25/08/2020 00:54:44
critical
25/08/2020 00:54:2
critical
25/08/2020 00:52:9
critical
25/08/2020 00:52:0
Warning!
Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/08/2020 00:50:4
critical
Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/08/2020 00:48:8
Warning!
25/08/2020 00:48:7
critical
SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/08/2020 00:26:45
critical
24/08/2020 15:27:1
Error
DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/08/2020 14:32:54
critical
  • 6.49K
  • 482
  • 851
Hero
Message 3 of 5
Some of your Downstream Power Levels are too high.
This will take an engineer to put right.
You can contact VM to report your problem using ...
Text service on 07533051809
150 from Virgin landline.
0345 454 1111 from any other UK  phone.
The best time to call is weekdays 08:00 to get a UK agent, anything after 10:00 you must realise that you are quite likely to get through to an offshore agent that doesn't speak English as a first language.
Or you can wait on here for one of the VM Staff to pick up the thread but this may take a few days.
Mike Robinson
Aircraft Engineer & Computer Based Training and Learning Designer for many of the world's Military Arms.
  • 719
  • 33
  • 70
Message 4 of 5
Good Morning @MarkDLC
Thank you for taking the time to reach out to us.
As @MikeRobbo has suggested, some of the power levels are on the high side.
I am going to drop you a PM so that we can arrange and engineer to come to you.
Kind regards,
Zak_M
  • 719
  • 33
  • 70
Message 5 of 5
Good Afternoon @MarkDLC
I just want to check how things have been since the engineer appointment?
Kind regards,
Zak_M
