kaadric
  • 17
Message 1 of 34
Connection Dropping
Hello VM Customer Service,
Seeing these message on the hub 3 box before connection drops and box needs rebooting.
No Ranging Response received - T3 time-out
Unicast Maintenance Ranging attempted - No response - Retries exhausted
Ranging Request Retries exhausted
Downstream bonded channels show as below.
1 138750000 4.1 38 256 qam 1
2 146750000 4.3 38 256 qam 2
3 154750000 3.9 38 256 qam 3
4 162750000 3.7 38 256 qam 4
5 170750000 3.4 38 256 qam 5
6 178750000 3 38 256 qam 6
7 186750000 3 38 256 qam 7
8 194750000 3.2 38 256 qam 8
9 202750000 3.2 38 256 qam 9
10 210750000 3.5 38 256 qam 10
11 218750000 3.7 38 256 qam 11
12 226750000 3.5 38 256 qam 12
13 234750000 3.5 38 256 qam 13
14 242750000 3.4 38 256 qam 14
15 250750000 3.4 38 256 qam 15
16 258750000 3 38 256 qam 16
17 266750000 2.9 38 256 qam 17
18 274750000 2.5 38 256 qam 18
19 282750000 2.7 38 256 qam 19
20 290750000 2.7 38 256 qam 20
21 298750000 3 38 256 qam 21
22 306750000 3.4 38 256 qam 22
23 314750000 3.2 38 256 qam 23
24 322750000 3.5 38 256 qam 24
Please advise.
Thank You
Richard
-tony-
  • 16.56K
  • 1.31K
  • 3.91K
Message 2 of 34
Re: Connection Dropping
post the second page from the downstream and the upstream figures
what is actually dropping - wired - wifi or both
____________________
Tony
kaadric
  • 17
Message 3 of 34
Hi Tony,
Just wired drops as the hub is being used in modem mode.
1 Locked 38.6 0 0
2 Locked 38.6 6 0
3 Locked 38.9 5 0
4 Locked 38.9 0 0
5 Locked 38.6 0 0
6 Locked 38.6 0 0
7 Locked 38.6 0 0
8 Locked 38.9 5 0
9 Locked 38.9 5 0
10 Locked 38.6 4 0
11 Locked 38.6 0 0
12 Locked 38.6 6 0
13 Locked 38.6 6 0
14 Locked 38.9 0 0
15 Locked 38.6 4 0
16 Locked 38.9 0 0
17 Locked 38.6 5 0
18 Locked 38.9 0 0
19 Locked 38.9 3 0
20 Locked 38.9 6 0
21 Locked 38.6 6 0
22 Locked 38.6 5 0
23 Locked 38.6 5 0
24 Locked 38.9 4 0
1 60300000 28.8 5120 32 qam 7
2 39400000 30.7 5120 16 qam 10
3 46200000 31 5120 16 qam 9
4 53700000 31.2 5120 16 qam 8
1 ATDMA 0 0 0 0
2 ATDMA 0 0 0 0
3 ATDMA 0 0 0 0
4 ATDMA 0 0 0 0
Thank You
regards
Richard
-tony-
  • 16.56K
  • 1.31K
  • 3.91K
Message 4 of 34
i assume thats not FTTP as i believe the upstream levels are different but even if it is the upstream is a mess and i would suspect thats the problem
will flag the thread to get VM here and get a tech booked to have a look if its not a known area fault
Tony
kaadric
  • 17
Message 5 of 34
Tony,
Thank You.
Much Appreciated.
regards
Richard
Sasha_W
  • 982
  • 40
  • 76
Message 6 of 34
Hi @kaadric,
thanks for posting this on here and welcome to the forum community!
Sorry to hear you're having some issues, I can appreciate this isn't ideal.
Do your drop outs improve at all when you reboot the box?
Do drop outs occur on all devices or is this something that happens on one device?
May sound obvious but is there an outage in your area which could be causing these drops outs? You can check the service status page here
How is your wired connection?
Sasha
Sasha - Forum Team
kaadric
  • 17
Message 7 of 34
Hi Sasha,
The drop outs do improve after rebooting the box.
The drop out occurs on all devices.
I did check for outages in our are and there were none for broadband.
The wired connection is where the failure is...and it's the only connection I use as the virgin router is being used in modem mode only.
regards
Richard
Sasha_W
  • 982
  • 40
  • 76
Message 8 of 34
Oh I see,
Okay so do these drops out occur roughly at the same time?
How long after rebooting does the drop out then occur again?
Have you tried switching out the ethernet cable for a different one if you do have another one?
Sasha
Sasha - Forum Team
-tony-
  • 16.56K
  • 1.31K
  • 3.91K
Message 9 of 34
@Sasha_W wrote:
Hi @kaadric,
Sasha
with respect - you are seriously asking the customer if there is a outage in his area - do you not have that info - if not then surely you need to go to pm to find out what area he is in and check
you make no reference to the upstream levels and qam
as to dropouts the hub is in modem mode according to the op and its the connection that drops - i.e. the connection to the hub - the reason i would suggest is the upstream levels
so again with respect - i think you need to look again @Sasha_W
and why would changing the lan cable stop the hub from dropping its connection as that is what seems to be happening
hmmmmmmmmmmmmmm
Tony
kaadric
  • 17
Message 10 of 34
Hi @sasha_w,
No the drop outs don't occur roughly at the same time.
This latest drop out has occurred after about 5 days.
Ethernet cable has been switched out twice.
Logs
30/03/2021 10:54:15 critical No Ranging Response received - T3 time-out;
30/03/2021 10:53:49 critical Unicast Maintenance Ranging attempted - No response - Retries exhausted;
30/03/2021 10:53:49 critical Ranging Request Retries exhausted;
30/03/2021 07:56:18 critical No Ranging Response received - T3 time-out;
1 138750000 3.9 38 256 qam 1
2 146750000 3.9 38 256 qam 2
3 154750000 3.5 38 256 qam 3
4 162750000 3.4 38 256 qam 4
5 170750000 3 38 256 qam 5
6 178750000 2.7 38 256 qam 6
7 186750000 2.7 38 256 qam 7
8 194750000 2.9 38 256 qam 8
9 202750000 3 38 256 qam 9
10 210750000 3.2 38 256 qam 10
11 218750000 3.2 38 256 qam 11
12 226750000 3.2 38 256 qam 12
13 234750000 3 38 256 qam 13
14 242750000 3 38 256 qam 14
15 250750000 3 38 256 qam 15
16 258750000 2.7 38 256 qam 16
17 266750000 2.5 38 256 qam 17
18 274750000 2.2 38 256 qam 18
19 282750000 2.4 38 256 qam 19
20 290750000 2.5 38 256 qam 20
21 298750000 2.7 38 256 qam 21
22 306750000 3.2 38 256 qam 22
23 314750000 3 38 256 qam 23
24 322750000 3.2 38 256 qam 24
1 Locked 38.6 328 0
2 Locked 38.9 162 0
3 Locked 38.9 85 0
4 Locked 38.9 62 0
5 Locked 38.9 42 0
6 Locked 38.9 76 0
7 Locked 38.9 86 0
8 Locked 38.9 39 0
9 Locked 38.9 53 0
10 Locked 38.6 41 0
11 Locked 38.9 36 0
12 Locked 38.6 56 0
13 Locked 38.6 46 0
14 Locked 38.6 39 0
15 Locked 38.9 52 0
16 Locked 38.9 19 0
17 Locked 38.6 48 0
18 Locked 38.6 50 0
19 Locked 38.6 74 0
20 Locked 38.6 42 0
21 Locked 38.6 53 0
22 Locked 38.6 48 0
23 Locked 38.9 54 0
24 Locked 38.6 53 0
1 60300000 30.3 5120 32 qam 7
2 39400000 29.8 5120 32 qam 10
3 46200000 30 5120 32 qam 9
4 53700000 30.3 5120 64 qam 8
1 ATDMA 0 0 47 0
2 ATDMA 0 0 10 0
3 ATDMA 0 0 48 0
4 ATDMA 0 0 39 0
Please advise next steps.
Thank You
regards
Richard
