Connection Dropping...
Hi all, I'm new to this forum and only had Virgin Broadband for a few months now but would appreciate any advice you can offer.
Connection has been great for the 2 months we've had Virgin and no issues. Turned the unit off yesterday whilst some work on our electric meter was carried out, the unit was powered down for an hour at most.
When rebooted there has been intermittent internet connection issues - connects for a while then disconnects and the green WPS light flashes for a while when there is no connection, it connects and the light goes out.
Is this the shape of things to come with Virgin broadband, as a search of the forum seems to indicate this...
  • 24.57K
  • 1.41K
  • 3.12K
Re: Connection Dropping...
What hub do you currently have?
Have you checked all the coax cables are secure?
Sorry, it would have helped if I told you that it is a Hub 3.
Yes, all coax cables are finger tight and have not been removed. Nothing was changed between the Hub powering down and booting up again.
Can anyone help with this, I'm still having issues with the connection dropping out. An engineer was booked to come last Friday but I stupidly cancelled as I thought the issue had magically rectified after a third reset of the hub...
This is what the hub shows, any advice appreciated.
14427500004.938256 qam30
21867500005.538256 qam7
31947500005.538256 qam8
42027500005.538256 qam9
52107500005.338256 qam10
62187500005.338256 qam11
72267500005.138256 qam12
8234750000538256 qam13
9242750000538256 qam14
102507500004.938256 qam15
112587500004.838256 qam16
122667500004.638256 qam17
132747500004.538256 qam18
142827500004.538256 qam19
152907500004.538256 qam20
162987500004.538256 qam21
173067500004.438256 qam22
183147500004.438256 qam23
193227500004.438256 qam24
20402750000538256 qam25
214107500004.938256 qam26
224187500004.638256 qam27
23426750000538256 qam28
24434750000538256 qam29
1Locked38.660
2Locked38.6200
3Locked38.9250
4Locked38.9130
5Locked38.9160
6Locked38.990
7Locked38.990
8Locked38.6180
9Locked38.9140
10Locked38.9130
11Locked38.9130
12Locked38.6100
13Locked38.9160
14Locked38.9170
15Locked38.6150
16Locked38.9170
17Locked38.9150
18Locked38.9200
19Locked38.9110
20Locked38.9200
21Locked38.6170
22Locked38.6190
23Locked38.680
24Locked38.690
13940000028.8512064 qam12
24620000028.8512064 qam11
35370000028.8512064 qam10
46029999328.8512064 qam9
2ATDMA0010
3ATDMA0010
4ATDMA0020
  • 11.7K
  • 913
  • 1.51K
The Upstream Channel Power Levels are too low.
This will need an engineer to put right.
You can either call in (08:00 is the best time) or wait on here for a few days (6 to 7 days average) until one of the VM Forum Staff comes along.
Mike Robinson
Thanks for your reply. I thought this may be the case after searching the posts on here.
I'll try to get an engineer out again...
