Travis_M
  • 919
  • 37
  • 69
Message 21 of 29
Re: Connection Disconnects
I see, is the service back on now? Is this via wireless or wired connection?
Travis_M
viperius
  • 15
Message 22 of 29
monitoring the wired connection.....out of the wall, into the back of the Hubv3 (in modem mode) into a Unify Dream Machine that have a number of switches, AP's and devices hanging off it.
Kenny
Travis_M
  • 919
  • 37
  • 69
Message 23 of 29
Absolutely everything is fine on our end after checking through my tools, the BQM looks fine, the hub powerr/signal levels etc and absolutely nothing suggests any reasoning our equipment / network can be causing the disconnects. Can you run the BQM over a 7 day period and keep us updated with the logs please?
Travis_M
viperius
  • 15
Message 24 of 29
ok Guys, had a few disconnects over the weekend, can clearly see them on the graph.....thanks goodness I was beginning to think I was imagining it..
Happy for any insight. Dont think anyone on the NW was doing anything out of the ordinary....
Kenny
Martin_N
  • 5.6K
  • 234
  • 322
Message 25 of 29
Thank you for that information. Please do provide us with BQM after 7 days.
^Martin
viperius
  • 15
Message 26 of 29
ok Chaps, BQM has been running for 7 days and I have had a few disconnects
Thursday 22nd - 1 disconnect
Friday 23rd - none
Saturday 24th - 2 disconnects
Sunday 25th - 2 disconnects
Monday 26th - none
Tuesday 27th - 2 disconnects
Wednesday 28th - None
Thursday 28th - 1 disconnect so far
They all happen at different times and nothing I am doing seems to cause it, least not anything I can see.
Kenny
My Broadband Ping - Home Connection
David_Bn
  • 5.41K
  • 247
  • 447
Message 27 of 29
Thanks for coming back to us, I've been able to run a flow on your connection and have been advised of the following;
Our system has identified a very short term connectivity issue which may cause intermittent or performance related issues with the connection.
We believe that the issue is only impacting this connection but it'll only be a very short term issue and the connection will return to normal very soon.
As the issue is only impacting you connection, please check that all cables are connected securely. The issue that has been identified may be the result of a loose connecting cable.
Kindest regards,
David_Bn
viperius
  • 15
Message 28 of 29
Thanks for that. Just checked all the connection from the box to the back of the superhub. They all seem to be tight. I have given them a finger tight turn.
This has been working without interruption for the last 4 years and only recently started doing this.....
I shall keep monitoring the connection and let you know.
Thanks for your help
Kenny
David_Bn
  • 5.41K
  • 247
  • 447
Message 29 of 29
Hopefully as the flow stated, this will clear up very soon and the connection will return to the expected standard
Our Forum Team will be on hand if you need any further assistance moving forward
Kindest regards,
David_Bn
