viperius
  • 13
Message 1 of 25
Connection Disconnects
Hi my network has been working fine and in the last 3 months it has started randomly disconnecting. This happens 4 or five time a day....
I have a hub 3 in modem mode
Unify Dream machine as my router.
All connected via ethernet.
I have extracted this from the logs. Seems when I am time traveling back to 1970 it causes some problems.
TimePriorityDescription
17/07/2021 14:42:47noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/07/2021 14:42:40Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:48criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/07/2021 15:52:43ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/07/2021 07:55:29criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/07/2021 05:51:44ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/07/2021 12:53:44criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/07/2021 12:53:33Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;0
1/07/2021 12:53:29Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/07/2021 12:53:28criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/07/2021 12:53:28Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/07/2021 12:53:27Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/07/2021 12:53:27criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/07/2021 12:47:21Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/07/2021 12:47:20criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/07/2021 12:47:20Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/07/2021 12:47:19Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Thanks for any insight
Kenny
  • 8.46K
  • 675
  • 1.51K
Message 2 of 25
Re: Connection Disconnects
FYI - 01/01/1970 is usually when your hub reboots and it has yet to get the time from the VM CMTS.
Please post your up/downstream stats and set up a BQM.
viperius
  • 13
Message 3 of 25
1475000000-0.738256 qam9
2483000000-0.938256 qam10
3491000000-138256 qam11
4499000000-138256 qam12
5507000000-1.238256 qam13
6515000000-1.738256 qam14
7523000000-2.237256 qam15
8531000000-1.738256 qam16
9539000000-1.538256 qam17
10547000000-1.938256 qam18
11555000000-2.538256 qam19
12563000000-2.738256 qam20
13571000000-2.538256 qam21
14579000000-2.738256 qam22
15587000000-2.738256 qam23
16595000000-338256 qam24
17603000000-2.937256 qam25
18611000000-2.938256 qam26
19619000000-3.438256 qam27
20627000000-437256 qam28
21635000000-4.237256 qam29
22643000000-4.237256 qam30
23651000000-437256 qam31
24659000000-4.237256 qam32
1Locked38.960
2Locked38.980
3Locked38.690
4Locked38.660
5Locked38.640
6Locked38.610
7Locked37.650
8Locked38.950
9Locked38.940
10Locked38.650
11Locked38.940
12Locked38.680
13Locked38.670
14Locked38.660
15Locked38.670
16Locked38.600
17Locked37.660
18Locked38.670
19Locked38.660
20Locked37.680
21Locked37.660
22Locked37.360
23Locked37.680
24Locked37.370
15370000046.8512064 qam7
23940000045.8512064 qam9
34620000046.3512064 qam8
43260000045.5512064 qam10
1ATDMA0010
3ATDMA0000
4ATDMA0000
viperius
  • 13
Message 4 of 25
I have had a BQM going for a while and the graph seem to be blank.
Kenny
David_Bn
  • 5.37K
  • 247
  • 445
Message 5 of 25
Good Afternoon viprius, and thanks for your post on our Community Forums, and a very warm welcome to you!
Can you please provide us with an update as to how the services have performed over the weekend? Do you have any graphs from the BQM or a live link that you can refer us to?
Kindest regards,
David_Bn
  • 8.46K
  • 675
  • 1.51K
Message 6 of 25
You need to set up a firewall rule to “Accept ICMP traffic” in the dream machine because pings from the internet are blocked by default and that’s what the BQM uses.
viperius
  • 13
Message 7 of 25
ok update from the weekend is that there have been no further drops in connectivity.
I have enabled the UDM firewall rule so hopefully we should get a BQM graph shortly.
Kenny
Gareth_L
  • 6.87K
  • 422
  • 775
Message 8 of 25
Thanks viperius
Looking forward to the BQM
Gareth_L
viperius
  • 13
Message 9 of 25
I think I must be doing something wrong as the graph is still red.....
Kenny
lotharmat
  • 2.54K
  • 189
  • 462
Trouble shooter
Message 10 of 25
Are you sure it is the right IP address being monitored?
