  • 13
Message 1 of 16
Connecting
When the engineer set up my system I could connect to either 5g or 2.4g.
I had to reset my hub and now I don't get the choice which means the signal is poor in parts of the house and the boosters are not working properly
  • 24.28K
  • 1.39K
  • 3.09K
Message 2 of 16
Re: Connecting
Login to the hubs admin page and split the Wi-Fi bands again.
  • 13
Message 3 of 16
Re: Connecting
Thanks Gary, I'm sorry but I'm not sure how to get in to the admin page.
I'm not overly good with technology
  • 24.28K
  • 1.39K
  • 3.09K
Message 4 of 16
Re: Connecting
Go to 192.168.0.1 in a browser and login using the admin password on the base of the hub
  • 11.31K
  • 887
  • 1.44K
Message 5 of 16
Re: Connecting
Type 192.168.0.1 into your browser URL bar and hit enter, then Log In using the Settings password.
You will need to set up your language preference etc.
Hub-3-Password
Mike Robinson
Retired Aircraft Engineer & Computer Based Training and Learning Designer for many of the world's Military Arms.
  • 11.31K
  • 887
  • 1.44K
Message 6 of 16
Re: Connecting
Refining your Wi-Fi management, it will certainly help keeping track of your Wi-Fi frequencies.
Best done with a cable connected device.
Instructions for Hub 3
Log in to the Hub.
Advanced Settings > Wireless > Security > Add 2 to the 2.4GHz Channel name [SSID] > Add 5 to the 5 GHz Channel name [SSID] > Click ‘Apply Changes’
Log out of the Hub then reboot using this method ...
Switch the Hub off using the small switch on the rear of the Hub next to the power cord and pull the PSU plug from the wall socket.
Give it a good 5 minutes put the plug back in and switch the Hub back on.
Allow the Hub a few minutes to fully restart then try your Wi-Fi again.
You will need to reconnect all you Wi-Fi devices some will want to connect to 5Ghz and some to 2.4GHz and some will connect to either.
When you connect the devices do it at the furthest point from the Hub that the device will be used.
Mike Robinson
  • 3.38K
  • 262
  • 461
Superfast
Message 7 of 16
Re: Connecting
...and an image if it helps:
  • 13
Message 8 of 16
Re: Connecting
Wish I’d waited and seen this screenshot. I just added a 2 and a 5 as suggested and now I have no internet at all
  • 13
Message 9 of 16
Re: Connecting
Ignore that last post - panicked. Internet back on so will check all other devices to see if I now have 2.4.
Thanks to all who posted
  • 3.38K
  • 262
  • 461
Superfast
Message 10 of 16
Re: Connecting
No need to panic. When you change the SSID the HUB drops and re-establishes the Wifi!
