Johnh1961
  • 6
Message 1 of 5
Connecting tv box to wifi
Was having issues with poor wifi with hub 3 so decided to buy another router and put hub 3 into modem mode,hub will not connect to tv box using wifi,just upgraded to tv360 and there doesn't appear to be any option in setting to change wifi network,I have 2nd box and was able to do it on that.Any help would be appreciated.
g0akc
  • 900
  • 84
  • 173
Well-informed
Message 2 of 5
Re: Connecting tv box to wifi
See page 19 section 2.9 here;
https://assets.virginmedia.com/resources/pdf/TV360.pdf
I recall you need to set on the location screen and use the remote
I know a bit about Wi-Fi, Telecoms, and TV as I used to do it for a living but I'm not perfect so don't beat me up... If you make things you make mistakes!
Johnh1961
  • 6
Message 3 of 5
Looks like you need to do this on initial software update from v6 to tv360 during setup,thought I'd try a reset of box but it needs connected to Internet to do this.
Johnh1961
  • 6
Message 4 of 5
Managed to get it,ethernet cable was still plugged in to back of tv box,once I unplugged it it connected to wifi.
lotharmat
  • 937
  • 70
  • 142
Well-informed
Message 5 of 5
Yay! - Glad that's sorted!
